Car stops unexpectedly, but restarts .
Old Sep 3, 2020 | 10:58 AM
Jag 8578's Avatar
Default Car stops unexpectedly, but restarts .
Hi Guys ,i have a 04 s type 2.7 diesel, 104.000 on the clock, it will at odd times just turn off while going along. i can restart ok but will be in limp mode . That said if i remove the key and restart its fine . Only does it odd times it has o new battery 18 months ago. Any help appreciated.
Old Sep 3, 2020 | 11:32 AM
kr98664's Avatar
Originally Posted by Jag 8578
i can restart ok but will be in limp mode.
Welcome to the forum. If your car has entered limp mode, it will have generated some OBD fault codes. Please post the codes and hopefully we can help you. If you don't have a scanner or code reader, most auto part stores will read the codes for free.
When retrieving the codes, please post the actual 5 digit code, such as P0174. Don't rely on the definition provided by your scanner or code reader, as those are not always accurate for a Jaguar. In some cases, the definitions can be downright misleading, so always go by the code itself.
Old Sep 3, 2020 | 12:44 PM
NBCat's Avatar
@Jag 8578, what is the voltage across the battery terminals with the ignition in the OFF position when checked with a voltmeter?
Bear in mind that most members on this forum are from North America where Jaguar never offered a diesel variant of the X200/X202.
Old Sep 3, 2020 | 01:29 PM
Jag 8578's Avatar
Karl thanks for the reply i will get a code reader and come back on the forum.
Old Sep 4, 2020 | 07:28 AM
M-e-l-l-o-w's Avatar
When you have the code (or codes) you can look it up yourself by downloading in the official Jaguar workshop manual:
http://www.jagrepair.com/images/Auto...M-Workshop.pdf
Danny Olds
XF (X260)
Aug 8, 2019 11:41 PM
essence head
Jul 26, 2019 08:17 PM
essence head
Jul 26, 2019 10:14 AM
Mike W
May 20, 2013 02:22 AM
morjags
Jan 5, 2009 07:19 PM
