Car won't start
Old Aug 7, 2017 | 01:32 AM
crwokc's Avatar
Default Car won't start
Car hydroplaned and slide backwards into guard rail. Car won't start and fuel pump emergency shut down switch button will not stay in!
2000 s type jaguar
Old Aug 7, 2017 | 02:02 AM
joesoap's Avatar
Is the security indicator on the dash going out when ign is turned on.
If it is, then if you are sure everything is working no fuel leaks etc disconnect battery for 5 mins and then reconnect and press inertia switch in again.
Listen to see if the fuel pump runs if it is, then you may be flooded put throttle to carpet and try to start.
Old Aug 7, 2017 | 03:25 AM
Originally Posted by crwokc
2000 s type jaguar
Welcome to the forum crwokc,
I've moved your question from XK8/XKR to S-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Aug 7, 2017 | 03:49 AM
JagV8's Avatar
Try the inertia switch (see handbook - but is often via a hole at the dash end).
JimC64
Sep 22, 2025 02:52 PM
macboots
Oct 13, 2016 08:26 AM
IcyWhite02
Oct 12, 2016 08:51 AM
Miss Charlee
Oct 5, 2016 07:03 PM
Mar 1, 2007 11:09 PM
