Cat System dash light ON
Old Feb 26, 2025 | 06:18 PM
MDZJaguarSTR's Avatar
Originally Posted by MrDeBruce
That post checks you have voltage at the damper connector from the ADRC (Damper control module) which is a good start.
He also needs to check the resistance across each damper to check they are not open circuit.
This has been suggested several times....
The codes he has are open circuit on three of the damper circuits.
Thats exactly what I have. So there can be an open circuit where? My Passenger and both rear have that code. I was told there’s a connector on one of the control arms in the front. The rear 2 I’ve unplugged and plugged in and I don’t see where a circuit could go short at??
Old Feb 27, 2025 | 09:30 AM
clubairth1's Avatar
Community Influencer
Why don't you measure it with a meter? You can't see shorts?
Again as posted above. Remove the plug at the top of the strut and measure across the pins?
Check if the plug is getting power AND what the resistance is across the strut pins.
Post back with your results.
Old Feb 27, 2025 | 11:00 AM
What should the voltage be when checking the damper??
Old Feb 28, 2025 | 09:43 AM
clubairth1's Avatar
Post what voltage your reading with your meter?
Have you done this yet?
Old Mar 1, 2025 | 03:23 PM
MrDeBruce's Avatar
Use the meter to measure resistance across each damper in ohms and post all four readings here.
Old Mar 1, 2025 | 04:12 PM
Ok, I will and ill get back to you guys
Old Mar 1, 2025 | 04:57 PM
scottjh9's Avatar
Maybe this will help some. I have an 06 s type r. Same cats system in good working order. Ignition off shocks plugged in is at 5.3 ohms. Ignition on car running is 1.3 milivolts plugged in. Some reference numbers anyway
Old Mar 1, 2025 | 06:15 PM
  #28
My apologies, where are you measuring if the bolts are plugged in?
Old Mar 1, 2025 | 07:26 PM
scottjh9's Avatar
where the wires enter the plastic plug on top
Old Mar 1, 2025 | 09:49 PM
  #30
Ok, I’ll keep you guys posted
Old Mar 2, 2025 | 04:08 AM
  #31
MrDeBruce's Avatar
I would not do this. You will damage the seals on the connector. Just measure the resistance of each damper across its pins.
Old Mar 2, 2025 | 07:06 AM
  #32
Ok, so measure the top of the Strut? Not the cable coming from the car
Old Mar 2, 2025 | 05:57 PM
  #33
scottjh9's Avatar
if you have the right leads it causes no damage....the pins inside the damper are very small and very close to each other....i choose the wires in lieu of damaging pins i cannot see
RGPV6S
Jun 6, 2024 12:27 PM
bigbaddog
Nov 30, 2021 01:39 AM
Ulysis
Jun 13, 2014 04:00 AM
androulakis
May 8, 2007 02:16 AM
