Catalytic Converter Delete
Old Feb 23, 2023 | 11:09 PM
2003JagStr's Avatar
Default Catalytic Converter Delete
I am going catless does anyone know how the car would sound like. And is there going to be any problems?
Old Feb 24, 2023 | 03:34 AM
JagV8's Avatar
I wouldn't want to post anything which might be considered negative so let us know how it turns out.
Old Feb 24, 2023 | 05:16 AM
kr98664's Avatar
Originally Posted by JagV8
I wouldn't want to post anything which might be considered negative…
Who are you and what have you done to JagV8? Release him immediately or I’m calling the authorities!
Old Feb 24, 2023 | 10:04 AM
NBCat's Avatar
At the risk of sounding negative, removing the catalysts is going to cause the MIL (Malfunction Indicator Lamp/Light) aka CEL to remain on. The PCM (Powertrain Control Module) uses the input from the four oxygen sensors to adjust the fuel trims for correct engine performance.
Old Feb 24, 2023 | 02:03 PM
iansane's Avatar
I didn't notice much sound difference going catless. Heck, I thought I was going to get that nasty catless smell my trans am has but I didn't. Maybe Jaguar's programming is just better. Who knows. But realistically, unless you can't afford new cats there isn't much of a reason to ditch them. It doesn't free up an appreciable amount of horsepower on these cars and to not get a check engine light you need to get rear o2 spacers from someone like Vibrant. I'd keep them if you have a choice to.
You sound like a child. Honestly though, there is a difference between being constructive about the pitfalls of an idea and being dismissive. You have a ridiculously large wealth of knowledge that you're nice enough to share with us, but you could work on your tact. Are you really offended that you were called out on that? No one is saying you have to change, but you can certainly be aware of how your responses come off to newer members.
Old Feb 24, 2023 | 04:15 PM
Joedotcom's Avatar
Hi
removing the cats will make the car louder
will also make it a bit perkier low end revs, does not make much difference top end
will also give lots of constant engine faults, this can only be stopped by mapping the cats out
you could try o2 foolers but they dont always work on these
cheers
joe
Old Mar 7, 2023 | 12:42 AM
Mclovin22's Avatar
Would suggest getting it tuned as well to eliminate the check engine light that’ll come on if you don’t. Imagine it’ll sound quite a bit louder and throatier. Have a tuner I could message you if you’d like.
kr98664
27
Jan 6, 2023 10:48 AM
sgvkirbster
Sep 12, 2017 11:52 PM
santer
Mar 13, 2017 12:46 PM
Jeff Carson
Sep 27, 2016 07:30 PM
ttreed_81
Dec 4, 2007 02:02 PM
