chain guide LH B-bank
Old Jan 20, 2026 | 08:23 AM
alifieris's Avatar
Default chain guide LH B-bank
Hello,
i would like to ask about the part number XR85175, its no longer available. What option do i have or there is an alternatine part number?
Old Jan 20, 2026 | 11:29 AM
clubairth1's Avatar
Community Influencer
When asking questions you need to help us out?
Zero car info?
Old Jan 20, 2026 | 11:53 AM
alifieris's Avatar
sorry about that!!
Jaguar s type 2001 model 3.0 cc v6 vin number of my car it's SAJAA01L81FM07946
Old Jan 20, 2026 | 12:12 PM
alifieris's Avatar
I have to change the timing chain & component kit but i cannot find the LH B-bak chain guide. Part number XR85175 its no longer available.
Old Jan 20, 2026 | 12:24 PM
NBCat's Avatar
What is the issue with the vehicle? What DTCs are stored leading to the timing chain being an issue?
The Duratech 3.0 litre is a very robust unit with very few issues having to do with the timing chains.
Old Jan 21, 2026 | 05:12 AM
alifieris's Avatar
check engine is on. The mechanic told me about the crankshaft and camshaft timing. We try to delete the error but the light its on again. Actually the mechanic doesn't remember the fault code because it was a few months ago.
Old Jan 21, 2026 | 05:44 AM
JagV8's Avatar
Oh!! Read the actual codes and post here.
Even a cheap elm327 can do it.
(Chances on that engine are it'll be nothing to do with what you're asking.)
Old Jan 21, 2026 | 09:17 AM
clubairth1's Avatar
Thanks much for the detailed car info as it does matter.
But as posted above your engine does not normally have that problem and without any actual codes I am afraid you will spend a lot of money when it won't be necessary?
So my suggestion is to hold off buying anything until a better and more accurate diagnosis can be done.
But your at the right place. All the answers for your car are on this forum.
Are you in the US?
Old Feb 10, 2026 | 08:46 AM
alifieris's Avatar
Hi , this part is mine and its in good condition i think , i would like to ask if i can use it again because the other guides are new, so 3 new guides and one used. Is it risky or not? Can i get a new one? The part number its XR85175 but its no longer available. New tensioners , guides , chains
Old Feb 10, 2026 | 09:49 AM
clubairth1's Avatar
You still missing the point? Changing random parts based on what a mechanic said months ago who can't remember the code will NOT work out!
Again what are the codes? Your 6 cylinder engine is not known at all for timing problems so the codes are critical.
It looks like now you took things apart and we don't know yet what exactly is the problem?
Old Feb 10, 2026 | 10:04 AM
alifieris's Avatar
its not possible to read the codes now, the mechanic when he removes everything he told me about the chain, it wasnt tight , so i already have 3 new guides 2 chains , 2 tensioners and 1 timing sprocket and i still missing one guide,can you help?
Old Feb 10, 2026 | 10:32 AM
alifieris's Avatar
All the parts in front of the engine are missing so its not possible to read the codes.
Old Feb 10, 2026 | 10:50 AM
clubairth1's Avatar
How much do you plan to spend on this?
It's looking like a bigger and bigger project.
Good luck!
Old Feb 10, 2026 | 10:53 AM
alifieris's Avatar
i am asking a specific question, if you dont want to help do not answer at all.
Old Feb 10, 2026 | 02:57 PM
scottjh9's Avatar
Wow
Old Feb 10, 2026 | 03:18 PM
JagV8's Avatar
Yeah
I'm out.
RandyS
Regional
Jun 29, 2022 03:09 PM
prawler
Jul 27, 2019 05:45 AM
Richxk8
Aug 24, 2014 11:37 PM
pdowning6
Mar 23, 2010 11:32 PM
