Changing ignition coils without a code?
Old Sep 22, 2013 | 06:55 AM
daboss085's Avatar
Default Changing ignition coils without a code?
I get a rought idle sometimes on startup and at lights once in a while. I do not have any lights or codes in the system showing, but would changing the coils help? I checked the coils and 3 out of 6 cars are different brands, not oem.... Thanks!
Old Sep 22, 2013 | 08:09 AM
police666's Avatar
Looks like you've found your problem, I'd change them for oem as soon as, a misfire will be damaging your cats.
Old Sep 22, 2013 | 08:53 AM
daboss085's Avatar
thanks for that info, even tho I do not have any check engine light on or any codes stored that I still have a misfire?
Old Sep 22, 2013 | 09:27 AM
police666's Avatar
You can have quite a severe misfire with no codes or light.
I had such a bad misfire my engine light used to flash when the revs got above 3k, indicating cat damage, but had no codes.
The problem was water in the coil/plug Wells, causing terrible misfire.
You can buy a cop (coil on plug) tester for about $80 on fleabay
Old Sep 22, 2013 | 03:03 PM
Richard Moss's Avatar
My 2001 4L had an annoying misfire and no codes. Replacing all 4 coils on one bank fixed it. If it hadn't fixed it, I'd have tried the new coils on the other bank!
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Bowman
Sep 3, 2015 03:17 PM
