Check Engine light 2003 S-Type
Old Mar 2, 2016 | 08:34 PM
hjt1948's Avatar
Default Check Engine light 2003 S-Type
I replaced left valve cover gasket as it was leaking.... while I had it off I had the cam solenoid unplugged and then I turned the key on too put the car in neutral to move it....everything is back together but the check engine light is on when I clear it...it comes back on...the engine is running very smooth and seems ok...but can't get the light to stay off any suggestions...
Old Mar 2, 2016 | 09:17 PM
Gus's Avatar
Gus
Rule #1 when working on your Jaguar disconnect the battery before you unplug anything!
Do a hard reset and be sure the code is cleared with your code reader. When you restart the car the engine will go to high RPM then it will go to normal idle.
Old Mar 3, 2016 | 02:25 AM
Welcome to the forum hjt1948,
Rule #1 when posting a technical question on the forum ........ give details of MODEL and YEAR.
Old Mar 5, 2016 | 09:34 AM
hjt1948's Avatar
Default Jag S type 2003
Ok Gus Hard reset undo battery for how long...???
Old Mar 5, 2016 | 05:20 PM
NBCat's Avatar
Disconnect both terminals at the battery; wait ten minutes, then touch the two terminals to each other for ten seconds prior to reconnecting them to the battery beginning with the positive (+) terminal.
Ubad2
Mar 10, 2016 12:28 PM
Pristine97XK8Convertible
Mar 4, 2016 11:57 AM
holybananas
Feb 3, 2016 09:22 AM
Dave Senske
Feb 2, 2016 05:53 AM
rcbarbier
Jan 30, 2016 05:20 PM
