Check engine light on but no codes
Old Jul 19, 2015 | 11:59 PM
caveforce's Avatar
Default Check engine light on but no codes
I had to send my jag (2005 S-Type R) to the shop to have the coolant hose under the supercharger replaced. While there the mechanic found the small vacuum leak that I had been searching for and fixed that too so the performance is back to normal. Although, when I received the car back the error message was on stating "press foot and parking brake" while an annoying beeping would only stop when the car was not moving. I messed with the parking brake for a bit and was able to get that to turn off but now the engine light is on but no codes are registering. I had the light reset but it is still on. Any ideas why the light is displaying while no codes register?
Old Jul 20, 2015 | 01:10 AM
JagV8's Avatar
Providing the MIL cycles when ignition is put on (like the other lights do), you're using a tool that is failing to report the codes properly. Change tool.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
big d
Sep 3, 2015 07:37 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
