Clearing codes
Old Dec 3, 2011 | 10:01 PM
01s-type1984's Avatar
Default Clearing codes
Is their a specific way to clear the dash codes such as gearbox fault and etc.???
Old Dec 4, 2011 | 09:52 AM
JagV8's Avatar
First, be aware that you can clear codes and get into a mess. It also clears the OBD monitors and it's possible (but fairly uncommon) that they won't Complete and then the car can't flag codes so you can get a car that's really hard to figure out.
For your era, both engine+gearbox are controlled by the one PCM. Any OBD tool can clear the codes or you can disconnect the battery for a couple of mins (though that also clears KAM where the learned stuff is so you force a relearn - don't do that if you still have engine faults present as it'll relearn goofy stuff).
All the other modules need a dealer-type tool such as AE (AutoEnginuity).
The plan behind OBD is that you diagnose and fix (note that part) before clearing codes. Codes self-clear when you've fixed the problem. The future OBD plan is that you will not be able to clear codes except via a fix and then self-clear because people are abusing the system all the time, with bad outcomes.
Shawn Svacha
Feb 6, 2022 04:53 PM
Bcrary3
Sep 12, 2021 05:41 AM
ccfulton
Sep 20, 2015 05:15 PM
dwgates
Sep 11, 2015 09:33 AM
mrplow58
Sep 9, 2015 11:27 AM
