CODE P1572
Old Jun 12, 2006 | 11:29 PM
Max's Avatar
Max
Default RE: CODE P1572
For what year Jag and model are you requesting info?
Old Jun 13, 2006 | 12:27 AM
Max's Avatar
Max
After searching the JTIS for XK8/R's and not finding the P1572 thought I had better ask. Sorry, can't help.
Old Mar 9, 2007 | 09:47 AM
oilman151's Avatar
More then likely the brake switch is bad. Yes 1572 is the brake switch circuit.
Old Mar 10, 2008 | 04:49 PM
Guatejag's Avatar
Hi! I also had a P1572 code read today at the shop, on a regular code check while doing others jobs. What "Brake pedal switch circuit malfunction" stands for exactly?, I see nothing wrong with my brake lights nor the ability of the car to stop. Where is the switch located? Is it just a DIY change job or something more complicated?
Finally, is this the switch we are talking about? http://www.autopartsworld.com/cart.asp
I'm sorry formakingso many questions in just one post, but I'm lost in this matter. Thanks in advance!
Old Mar 10, 2008 | 05:48 PM
jag_genius's Avatar
brake switches do more then turn your brake light on and off.
Old Mar 10, 2008 | 06:45 PM
FactoryJaguarTech's Avatar
Like cruise control.
Old Mar 10, 2008 | 06:47 PM
jag_genius's Avatar
and they also stop tranni upshifting if staying on.. or slightly on..
Old Mar 10, 2008 | 07:07 PM
We had a guy that kept coming in with 2004 XJ complaining of no upshifts. Kept driving it and was fine. Eventually went for a ride with him driving. Told him to take his foot off the brake and low and behold....car shifted normally.
Old Mar 10, 2008 | 07:11 PM
jag_genius's Avatar
lol
Old Mar 10, 2008 | 09:06 PM
Guatejag's Avatar
Thanks for your answers, I gotta honestlytell you that I am not mechanical oriented at all, sorry. So, the malfunction could be affecting a series of things, right? Do you thinkthat changing theswitch will solve things out?, and again, is changing it a DIY job or something more serious?, where is theswitch located? Thanks again!
Old Mar 11, 2008 | 06:30 PM
Located on brake pedal. There is two of them. You can do it.
Old Mar 11, 2008 | 06:53 PM
jag_genius's Avatar
if it's not the sensor.. i had one where it needed a harness.. hopefully it's the switch
Old Mar 11, 2008 | 09:54 PM
Guatejag's Avatar
mmm... is there a way to check if it's onlya blownswitch?
Two of them? are they equal or each manages different things and have different part numbers?
Old Mar 12, 2008 | 05:45 AM
Both different. One activates a few ms before other. If intermittent problem, hard to check. Just replace both.
Easiest way is to have car running and press brake pedal, do not disconnect electrical connector. Turn 1/4 turn ccw and pull them out. Shut car off, disconnect electrical connectors. Plug new ones in then start car. Reinstall and enjoy. Get code cleared.
Old Mar 12, 2008 | 09:36 AM
lol
ACM functioning ok Bo?
Old Mar 12, 2008 | 11:04 AM
Guatejag's Avatar
ccw?
Old Mar 12, 2008 | 03:07 PM
counter clockwise.
