code p1633
Old Oct 10, 2008 | 11:36 PM
cosworth's Avatar
Default code p1633
KAM voltage too low.
I posted this once before and wanted to see if a jag tech could shed some light.
All fuses, relays, connectors are all clean. Continuity is good everywhere. 12.2 new in the morning. 13.7 idling. Everything checks out. I know the battery is not %100 tested with just a multimeter. Every single link I've seen has no resolution. Is this just a battery on the way out? Seems futile. I know I take this to the dealer and I'll be stiffed for a new battery and PCM. Throw a battery in there? It cranks just fine, holds a great charge....
Old Oct 11, 2008 | 08:28 AM
racerx82's Avatar
Default RE: code p1633
I'll get you a detailed diagnostic as soon as i return from : getting coffee and breakfast...and a haircut. No shave, just a hair cut...and by haircut, i mean a real haircut, not the kind of haircut you get when you're in Korea...if you get what i'm talking about....
Old Oct 11, 2008 | 05:37 PM
cosworth's Avatar
Well I tried a brand new battery. Still the code persists.
Interesting though, the new battery I guess was sitting on a shelf for some time. It was reading 10.3 volts. So I drove around a bit. If you turned off the engine for say 10 seconds then did a KOEO test the code would clear. KOER test, the code came back right away. After I charged it up to 12.5v after a 20 minute drive, the code would not clear at all (KOEO or KOER) and the idling voltage was the same at 13.7. that was weird.
At this point I think the PCM is dead. NOT a cheap fix.
Old Oct 12, 2008 | 10:09 AM
racerx82's Avatar
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 Style Definitions table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:"; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} I just checked alldata and code P1633 does not point to KAm voltage.
possible causes: ECM default: throttle motor or throttle relay disabled; throttle valve set to default openeing; idle speed controlled by fuel injection intervention; idle speed adaption inhibited.
But you are correct in the assumption, that is all checked out the ECM is fried.
Old Oct 12, 2008 | 09:42 PM
cosworth's Avatar
Yep, crap.
P1633 Jaguar Main processor unit failure malfunction
That's the jag specific code. I guess I'll be looking on ebay for one of these.
Old Oct 12, 2008 | 10:04 PM
racerx82's Avatar
I have no idea what happened to my post above.....no way i drunk...lol
Old Oct 12, 2008 | 10:35 PM
cosworth's Avatar
Thankfully they are cheap. eBay has a couple and the prices vary wildly. Just have to make sure they send the engine computer and not something else...
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
