Codes After Manifold Removal for Plugs/Coils
Old Mar 3, 2018 | 06:42 PM
MikeofBonsall's Avatar
Default Codes After Manifold Removal for Plugs/Coils
I changed the plugs and coils on the 3L 2007 S-type. Afterwards car ran great but threw all theses codes like some leads or hoses have not gone back right.
CODES:
P0174 Bank 2 lean
P0327 Knock sensor B1
P0171 Bank 1 lean
P0664 Manifold tuning valve low bank 2a
Obviously I have stripped her down again but find no loose leads or hoses. Anyone know what to check?
Old Mar 3, 2018 | 08:31 PM
joycesjag's Avatar
CODES:
P0171 Bank 1 lean
Are you sure the imt valve was plugged in correctly. That would cause the lean bank too.
Old Mar 3, 2018 | 08:46 PM
OK i looked back there and I see what you mean but how total;l if the connectors are good. They are plugged in.
Old Mar 5, 2018 | 11:38 AM
NBCat's Avatar
Check the plugs to the fuel injectors that they are correctly connected.
Check around MAF and inlet manifold for vacuum leaks.
Old Jun 1, 2018 | 10:01 AM
Thanks all. Now cured just air leaks but I needed get my mechanic run the smoke detector to find them.
MikeofBonsall
Jan 28, 2018 07:07 PM
unpredictable1
36
Jun 20, 2017 09:05 PM
WillieE
May 17, 2011 11:14 AM
GaryinOregon
Jul 11, 2010 08:18 PM
2000SType40
Sep 21, 2009 05:46 AM
