Hello,
Please help me with 2 codes for the rear suspension bushings at the shock absorber at the bottom and at the lower arm. I circled them in red in the picture. Thank you very much for your help.
By "code" I am assuming that you mean "part number". The part number for the shock bush is C2D4013. The bushing for the lower control arm does not appear to be listed separately, though they may be available in the aftermarket.
There are two versions of the lower control arm, pre and post initial facelift, the break comes at MY 2002.5... I believe Moog in the States makes one version, but their parts listing system is incorrect as I recall.
Also, when you find time, please stop by the New Members forum and post the expected "introduction"; this will help you to achieve more forum privileges. The new members forum can be found here:
Thank you very much for your answer.
Yes, you are right... part number, not code.
For the lower arm, I ordered a bushing yesterday that was too small, it was probably for the pre-2002 version.
Best regards!
Hello,
I changed the shock absorber bushing and it fit perfectly.
I couldn't find the bushing for the lower arm. I think the solution is to change the whole lower arm.
