codes and warnings galore
Old Mar 26, 2010 | 06:13 PM
super_jag's Avatar
Default codes and warnings galore
well i finally put the Jag back together, 2003 S-Type r, and it ran fine to the end of the block i got engine system fault and all gauges quit on me all emergency lights were on but the car was still working well under 1200 rpms it was. Now I turn on my car and get greeted with dcs not availabe, cruise not available, engine sytem fault and parkbrake fault. I apply parkbrake, and it works. I press gas pedal and it slowly revs to 2000 rpms. brakes are a little hard. I will get codes soon.
Old Mar 26, 2010 | 06:20 PM
super_jag's Avatar
codes p0646 comes up twice and p0121 and p1000
Old Mar 26, 2010 | 06:27 PM
JagV8's Avatar
P1000 means monitors not complete since last clear. OK unless you've done plenty of varied driving since then.
P0121 is TPS-related, P0646 is A/C-related. Odd. Could be a failing battery or other power problem (bad ground, etc).
Old Mar 26, 2010 | 06:57 PM
super_jag's Avatar
well i was poking around and found a puddle of water in passenger back seat. so i checked fuses and behold my ecu was dripping wet.... we had a snow storm and my car was not in garage will i had removed the box for the cabin filter.
Old Mar 26, 2010 | 07:31 PM
JagV8's Avatar
Blot up excess water from modules, then dry out somewhere warm but not too hot. Hope they're not damaged!
Old Mar 26, 2010 | 08:37 PM
Riski's Avatar
eekkkk.....that sucks about getting your fuse box all wet....hope it dont cost....
Old Mar 27, 2010 | 03:41 PM
thep's Avatar
Default codes & warnings galore
My 03 S-Type 4.2L acted up the same way, only the car has had no work done recently. Was this the fuse box in the trunk or under the hood? I had checked both yesterday and saw no moisture, but will now have closer look. Also, I have been driving in dry weather and the car is always garaged. Please let me know how things work out for you.
Best regards,
Jpav27
Jul 31, 2022 06:43 AM
ericjansen
Dec 19, 2021 12:20 AM
Johnken
Sep 15, 2015 05:46 PM
fingers
Sep 11, 2015 12:21 PM
mrplow58
Sep 9, 2015 11:27 AM
