Coils and Spark Plugs
Old Sep 4, 2009 | 09:20 PM
Kennedy's Avatar
Default Coils and Spark Plugs
My 2001 Jag s-type 4.0l V8 with 211,700km on it. It has a misfire in cylinder 7 according to the OBD-II code reader. It is even noticeable when someone hears the noise coming from the exhaust. when stopped it studders and it hesitates a bit on take off. Does anyone know what might the problem be? Im thinking spark plugs or coils.
can someone tell me where the spark plugs are located on the V8 and how do i get to them?
Is there a jag replacement coil. i called Ford and they say i have to go through Jag because the didnt have the catalogue, even though they are ford made. Is there a part # on another ford with the same coils? i heard the Lincoln LS uses the same coils, not sure if this is true though. If so, what year?
Has anyone heard of coils made by BLUE STREAK? Are they any good?
Old Sep 6, 2009 | 11:11 AM
steinmetz's Avatar
I had the same with my 4.0 V8.
I just needed to replace on of the coils then everything was fine ok:
IGNITION COIL ( AJ81373 ) #XR827823
JAGUAR ON PLUG IGNITION COIL - V8
JAGUAR S TYPE 4.0 V8 1999 - 2002 END AT VIN M45254
8 REQUIRED
IGNITION COIL #AJ810445
JAGUAR S TYPE 2002 - 2004 VIN M45255 TO N13088
8 REQUIRED
I usually order my parts in the UK: http://www.britishparts.co.uk/
Hope this helps!
Old Sep 7, 2009 | 01:08 AM
ohsigmachi's Avatar
USE EBAY COILS!
http://cgi.ebay.com/ebaymotors/2000-...=p4506.c0.m245
purchased installed and ran for 2 years no problems.
As for replacement of coils there is an access panel on the top of each cylinders valve cover held on by several 10mm headed bolts. Each coil is held in by one 13mm headed bolt and the wire clip. once the bolt and clip are removed simply pull up on the coil. Standard spark plug socket on 6in extension wil remove the plugs.
Happy hunting.
Old Sep 7, 2009 | 11:45 AM
Kennedy's Avatar
Thank you very much for all your help everyone.i called NAPA and the ford dealers and they said the part# is DG-515 made by motorcraft which are the same as the 2006 lincoln. i will tackle this problem immediately.
Just curious who makes the coils for Jaguar? wonder if they are also by motorcraft?
thanks guys
Anyone know what the spark plug gap should be set at? Not sure if its .050 or .052
Old Sep 7, 2009 | 11:23 PM
ohsigmachi's Avatar
thanks guys
Yes, original coils in Jaguars S-type engines were sourced from Motorcraft. When I replaced my original coils on my '00 S-type six of the eight coils were Motorcraft parts (I'm assuming the other two were replacement coils). The serial number cast into the plastic of the original Motocraft coils (a parts casting number by the actual coil manufacturer) was actually the exact same number as the replacement coils I purchased off of E-bay.
Bottom line, only a handful of companies make these coils (possibly less than three worldwide), so any replacement part sold under any name brand is likely to come from the same factory and be THE EXACT SAME COIL, doesn't matter if the box says Jaguar, Motorcraft, or NAPA; they are all the same coil from the same couple of factories.
Old Sep 8, 2009 | 06:35 AM
JOsworth's Avatar
Very true...
Here is another little example. I don't think I'll get in trouble for revealing this......
I work for a conection systems distributor. One of our main suppliers is Delphi.. So, Delphi is GM right? Well, not really. We ship Delphi connectors and terminals to just about everyone. From wire harness manufacturers to the likes of Ford, Chrysler, Toyota, Harley Davidson, John Deere, and the list goes on. So, the auto world is really quite the complicated web....
Old Sep 8, 2009 | 07:48 AM
joycesjag's Avatar
I am seeing a gap of .051, and torque on the plug 15Nm (11ft lb).
Old Sep 8, 2009 | 04:17 PM
Kennedy's Avatar
ok, so now i have an issue in buying the NGK double platinum plugs since nobody caries thenm in edmonton or calgary. I gues i will replace them with autolite double platinum with a gap of .050". Does anyone know if i will have any problems with these spark plugs? i don't know much about then.
thanks all.
Old Sep 11, 2009 | 12:22 AM
Kennedy's Avatar
Default changed sparkplugs
ok, so i changed all the spark plugs today and it was quite a simple job. however, i ran into a huge problem. the person who previously did them, installed the furthest spark plug close to the fire wall on the left side crooked. i guess, it was cross threaded. i carefully installed the new double platinum but it doesnt seem to want to completely tighten up. the car still runs with code misfire cylinder 7. what do i do now? i am waiting for my coils to arive. how do i fix the spark plug thread?
Old Sep 11, 2009 | 12:30 AM
IMHO if the car is not spitting the plug out it is probably not the cause of the misfire.
A helicoil is the answer to the thread problem, but you need to speak to a specialist to do it in place.
Old Sep 13, 2009 | 11:04 AM
Kennedy's Avatar
Ok, I realized that the firing order of this 4.0 is different. Left side from the front to back cylinders are 1,2,3,and 4. The right side from front are 5,6,7, and 8. Switched coil 7 with coil 6. Now, the misfire shows up on cylinder 6. I guess that the problem is the bad coil. will replace all 8 when they arrive and will let everyone know the result. thanks all
Old Oct 13, 2009 | 10:17 PM
Kennedy's Avatar
All 8 coils replaced and the car now runs very well.
Old Oct 14, 2009 | 07:10 AM
joycesjag's Avatar
Congradulations Kennedy. What did you do about the crossed threaded spark plug?
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
Bowman
Sep 3, 2015 03:17 PM
