Cold Start - "Lurch" Restricted Performance
Old Nov 10, 2010 | 09:15 AM
Mesmerizing_k's Avatar
Smile Cold Start - "Lurch" Restricted Performance
I have a 2003 S-Type and on cool days the car jerks and runs on low power (no anti-lock brakes) and an error message Restricted Performance displays on the dash. Once the car warms up it runs perfect. Any ideas?
Thank you
Old Nov 13, 2010 | 08:03 AM
Now the Gearbox Fault light is on. Another peculiar action is that often when the car is cold and until the engine is warm the volume on the radio does not work. In the afternoon, when I get back in the car the radio is usually working. What is involved in reparing the faulty gearbox ?... Thank You!
Old Nov 13, 2010 | 08:08 AM
Mikey's Avatar
I'm sure one of the mods will move this to the S-type section, but multiple electrical faults are sometimes caused by water leaking into the trunk. Lift up the floor to access the battery and have a look.
Old Nov 15, 2010 | 05:43 AM
victor's Avatar
Smile
How old is the battery? A failing battery can cause all sorts of problems. It's a well known fact.
Old Nov 15, 2010 | 12:53 PM
H20boy's Avatar
viola! moved...
Old Nov 15, 2010 | 01:05 PM
Mikey's Avatar
Ten jew beddy mutts.
Old Nov 15, 2010 | 01:57 PM
JagV8's Avatar
Not that sort of cold!!
Hope it's a failing battery cos if it's something else it'll probably be far harder to track down.
Old Nov 16, 2010 | 03:22 AM
Would you believe a bad O2 Sensor.... .
Old Nov 16, 2010 | 04:07 AM
JagV8's Avatar
Was the car running CL (closed loop) on the bank with that? Were there any codes?
Old Nov 16, 2010 | 07:04 AM
joycesjag's Avatar
I believe this is a first, but what do I know.
Old Nov 17, 2010 | 09:03 AM
SPECTOIL's Avatar
Hi, I'm new and have similar problems. Starting yesterday the check engine light pops on when I driving to my work. Feel strong transmission failures, it's like "skating" (hight RPM and the car is slow moving). Today we'll take the codes to see if anyone can help me!!!
Old Nov 17, 2010 | 09:06 AM
SPECTOIL's Avatar
Also, when the car fails display the gear box failure menssage
Old Nov 17, 2010 | 10:08 AM
bfsgross's Avatar
Check the battery for charge and/or weak cell(s). If the battery is more than four years old, it's likely slated for replacement anyway.
Old Nov 17, 2010 | 10:35 AM
SPECTOIL's Avatar
Thanks bfsgross, I will verify.
On Monday, accidentally left the lights on and draining the battery completely. Using a jump my car ignition cables and the next day (yesterday) started to make mistakes.
Think I can disconnect the negative terminal of the battery to reset the ecu help to resolve part of my problem?
Old Nov 17, 2010 | 10:37 AM
SPECTOIL's Avatar
I'm at work now but I had to stop more than 6 times on the road, turn off the car to continue. Need help to return to my house driving the car: (
Old Nov 17, 2010 | 11:17 AM
tbird6's Avatar
SPECTOIL;
Please put you car details in your signature so we know what your talking about.
Thanks!
Old Nov 17, 2010 | 02:07 PM
SPECTOIL's Avatar
tbird6,
Done!!! I think is ready!!
Old Nov 17, 2010 | 02:19 PM
JagV8's Avatar
So... what are the codes?
Old Nov 17, 2010 | 02:25 PM
SPECTOIL's Avatar
jagv8,
I'm in my work now, I try to verify all codes in my hose.. BTW... another thing... my Jag have 165,000 miles and counting
Old Nov 17, 2010 | 02:33 PM
JagV8's Avatar
Had me puzzled.... hose = house, i.e. when you're at home
OK.
