Control Arm Assembly - Rear Left/Right
Old 12-30-2023, 05:21 PM
ampiko's Avatar
Default Control Arm Assembly - Rear Left/Right
Greetings,
I have a 2003 S-Type R. The mechanic told me that I need to replace the Rear Control Arms Upper+Lower with Ball joints. (Moog, Detroit axle, TrueDrive)
I found a couple of Rear-Upper assembly with Bushings+Ball joint. However, I cannot find any for Rear-Lower that Includes the Ball Joint . Perhaps there is No Ball joint for Rear-Lower ? Please Advise Thanks
Old 12-31-2023, 12:15 PM
xalty's Avatar
Received 1,053 Likes on 846 Posts
no ball joint on the lower
ampiko (12-31-2023)
Old 12-31-2023, 06:35 PM
S-Type Owner's Avatar
Be careful in selecting replacement bushings for the lower control arms, if you decide to go that route. There are some erroneous listings that (i believe) started with Moog and were replicated all over the internet,
kr98664 (12-31-2023)
Old 12-31-2023, 07:27 PM
kr98664's Avatar
Received 1,999 Likes on 1,411 Posts
Are you planning to have your mechanic do the work and supply the parts yourself? If so, I don’t recommend that combination. It’s generally best to let the mechanic supply the parts, too.
Even if you can save a little money doing so, there’s a big potential downside. Let’s say something acts up a few months down the road, still within a typical warranty period. Your mechanic will quickly say the part was at fault, not his work. You are now responsible to supply any needed replacement, plus pay for the labor. If the mechanic had supplied the part, he’d still be responsible for the whole thing.
Old 12-31-2023, 08:31 PM
ampiko's Avatar
Thanks. i am replacing the complete assembly
Old 12-31-2023, 08:35 PM
ampiko's Avatar
the mechanic doesn't want to find the parts and i don't want to spend OEM money. Any recommendation on somewhat dependable after market brands ? Thanks
Old 01-06-2024, 06:21 PM
xalty's Avatar
get aftermarket arms for a lincoln ls
or arms for an 05+ and washers to take up the space
ampiko (01-07-2024)
pcolapacker
01-18-2022 02:40 AM
Patrick Wong
06-14-2021 09:34 AM
Wingrider
05-03-2019 05:57 PM
usmc1211
08-22-2014 10:21 AM
Jag69
02-19-2010 05:51 PM
Quick Reply: Control Arm Assembly - Rear Left/Right
