Coolant Fan??? can it be straight wired to run on high.
Old Mar 8, 2012 | 10:18 AM
Precha's Avatar
Question Coolant Fan??? can it be straight wired to run on high.
My fan worked when I had it off the car and plugged up. Now the fan is on the car it only spins real low, first issue with the fan just curious if it can be hot wired on a switch.
Old Mar 8, 2012 | 10:27 AM
JagV8's Avatar
I suppose it must be possible but why not find out if it's actually doing the wrong thing and if so why?
Old Mar 8, 2012 | 01:02 PM
Precha's Avatar
Yes it works when I hook the 2 speed control wires to a hot so it sounds as if the relay is out maybe?. Where is the fan relay and the lighter fuse I do not have a clue.Thanks any help will be appreciated trying to keep this all Original....
Old Mar 8, 2012 | 01:49 PM
JagV8's Avatar
You really should get JTIS as it has both electrical diagrams and details of where things are plus how to remove/install.
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
Raul Lara
Sep 14, 2015 07:31 PM
Bcrary3
Sep 3, 2015 03:48 PM
