Coolant leak
Old Apr 23, 2014 | 12:27 AM
Muslima36's Avatar
Default Coolant leak
Looked under the hood n noticed orange coolant leaking down a hose, Un-sure of the exact problem area, or which parts r needed..Any takers?
Old Apr 23, 2014 | 02:10 AM
JagV8's Avatar
Either you narrow it down or replace parts a bit randomly hoping to get lucky - can be very costly. Or don't DIY.
Old Apr 23, 2014 | 02:56 AM
police666's Avatar
Fix the leak
Old Apr 23, 2014 | 11:01 PM
Blucarman's Avatar
Usually it is the small tube at top of coolant reservoir that develops a crack.
Check where the small hose is clamped. If that is where the leak is, replace the reservoir. Do not attempt gluing, will never work. The system is pressurized. Hope you find the leak soon & Good luck
Old Apr 24, 2014 | 06:17 PM
hayirichie's Avatar
I been having a few leaks lately on my 4.0. Finding the source can be tricky sometimes. Look with a flash light at the top rear of the motor in the intake valley. If you see coolant there its the 3/4 to 3/8 fitting under the intake. If the leak appears to be at the rear its a good idea to take the plastic off that covers the radiator fill tank. There is a large coolant hose in the top front passenger side. It has what looks like a coupler but it is a tee with a small 3/8 hose on the bottom. It also could be a connection at the dccv.
Old May 1, 2014 | 07:22 PM
Muslima36's Avatar
Getting my baby fixed n the morning..yay!
arskemp
Sep 21, 2015 02:19 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
