coolant leak
Old May 25, 2012 | 01:16 PM
93XJR-S's Avatar
Default coolant leak
so my 03 STR has succumbed to the coolant bottle leak, thing is it only leaks a tiny bit from the heater purge screw, must have over tightened it, can i spread some silicone on the threads to seal it up for now ? or perhaps an appropriately sized ac oring underneath? I'll replace the whole bottle one day but for now it seems a bit excessive for this issue
thanks
paul
Old May 25, 2012 | 02:10 PM
Worth a try I'd say, you have nothing to lose.
Old May 25, 2012 | 08:57 PM
93XJR-S's Avatar
ah, just a regular o-ring of the correct size should fix it, looks like exceeding the 1nm torque rating, in my case 10 or so nm seems to get the thing distorted and caught in the threads.
Old May 8, 2024 | 09:19 PM
tourdotc's Avatar
I have a coolant leak in my '05 STR and believe it is coming from the component circled in the image below. Can someone tell me what that component is please? Thanks!
Old May 8, 2024 | 10:01 PM
Beretta9's Avatar
Dual climate control valve. They are prone to failure.
Old May 8, 2024 | 10:22 PM
tourdotc's Avatar
Thank you!
Old May 9, 2024 | 08:13 AM
S-Type Owner's Avatar
If you are looking for a replacement part, please steer clear of no-name units for sale on that famous auction site; they are most likely made by the Sum Ting Wong Parts Manufactory #27 in Flung Dung, China. Stick with OE, or Bosch (which is the OEM). That is, unless you like leaks and replacing parts on a regular basis...
JaguarXJL15
Mar 5, 2024 09:18 PM
Car Crazy
Oct 30, 2023 10:59 AM
Drak
Dec 11, 2015 03:45 PM
CCJagtyper
Feb 20, 2012 11:39 AM
sinatrakat
Sep 13, 2010 04:20 AM
