coolant spraying out
Old Sep 9, 2014 | 07:58 PM
mgherghina's Avatar
Default coolant spraying out
I'm having heavy leaking on the umber side of my car dripping coolant or water? Down my oil Pan and it's lightly spraying out water on the upper side of the engine... Wtf is going on ? Any help would be much appreciated gentleman.
Old Sep 9, 2014 | 11:44 PM
mgherghina's Avatar
it seems as if the water is being spun up by the belt and spraying all over my engine.. what could cause this ?
Old Sep 10, 2014 | 01:27 AM
JagV8's Avatar
A leak from any of lots of places. Go hunting with a strong light. Dry as much as you can if you don't find it quick then see what gets wet first. Beware moving parts!
Old Sep 10, 2014 | 10:01 AM
Rambunctious Jaguar's Avatar
Whats your car info ?
Recently changing my thermostat assembly, Id say start there
but do as suggested clean up the engine bay and look with a flashlight for fresh leaks
Old Sep 10, 2014 | 06:11 PM
mgherghina's Avatar
i seem to have found ( or at least i think ) the culprit. It looks like my water pump may be busted, I've felt in the past as if it was kind of failing ... could this be possible ?
Old Sep 11, 2014 | 03:55 AM
It could be, I recently changed that out too,
and vehicle info please, I now understand the frustration felt by you seasoned members
Old Sep 30, 2014 | 09:20 AM
Norm St.Onge's Avatar
I had the same problem it turned out to be the o-ring around where the impeller enters the motor. removed water pump thinking it was failing but the o-ring turned out to be the culprit. new gasket should be used tighten bolts in star pattern. good luck
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
