Cracked defroster / demister vent panel
Old Jul 29, 2017 | 12:30 PM
bendebusk's Avatar
Default Cracked defroster / demister vent panel
I've read a lot about the common issue of a cracked defroster/demister vent panel. I checked the price of a new panel and also (half-heartedly) looked for a used one, although I worried about ending up with the same issue later. Not to mention the effort required to actually replace the panel once I had the part.
I toyed with the idea of simply buying a dash cover to hide the cracked panel, but didn't like the look of a gigantic cover over the entire dash. So I reached out to a manufacturer to ask if they would be willing to do a semi-customs version of an S-Type Jaguar, based on the regular dash cover they offered. They agreed!
So I wanted to pass along this option to other Jag enthusiasts, in case you face the same dilemma. The photo (attached) doesn't really do it justice, but I think you get the idea.
Here's link to purchase from their online shop: Dash Cover - Jaguar S Type 2000-2002 *Defrost Vent Arear Only!
Hope this helps!
Attached Thumbnails Cracked defroster / demister vent panel-defroster-vent-dash-cover.jpg
Old Jul 29, 2017 | 01:33 PM
abonano's Avatar
Wow, looks good.
If you decide you need a used replacement demister panel I have one, in charcoal for 2000-2002 S Type. I was going to replace mine but sold the car.
PM me if interested.
Old Jul 29, 2017 | 04:52 PM
bendebusk's Avatar
Thanks, abonano. My interior is cashmere (tan). But you can't really tell in the photo.
Old Jul 29, 2017 | 05:59 PM
DigitalDisaster's Avatar
That's a great idea. Living in Arizona, I bought a dash cover mainly to protect the demister panel, only find it was cut out in most of that area
Old Aug 16, 2017 | 01:34 PM
VTGBoss's Avatar
That is a cool cover. One of the defroster vents on my 2003 X-Type broke and the cost of replacing it is ridiculous. Your cover is a nice alternative. Having said that, I called the company that manufactured yours and they indicated that they did it per a customer request, likely you, but did not work and will not do it again; very surprising.
How is that cover working for you? Is it carpet, velour or suede? Do you know of another supplier that has something like it but for the X-Type? The other option is to go to an upholstery shop and see if they can cut the pattern (should not be too difficult) and trim the edges...probably more expensive than buying the part from Jaguar.
Old Aug 16, 2017 | 07:15 PM
bendebusk's Avatar
That's too bad. I had some back and forth with the manufacturer until we had the right pattern. Then when I ordered the new design, they ended up shipping the whole dash cover, instead of the custom product. That frustrated the guy with whom I was working. But they sent me the custom version (carpet-style) and told me to keep the other one too. So they may be gun-shy trying to do this for another model.
If the pattern already existed somewhere online, it'd probably be an easy thing to get produced. Sorry I can't be of more help!
Old Aug 17, 2017 | 11:51 AM
triad_ajr's Avatar
I don't know, I used the link you gave and ordered one on August 16, they processed it, as of yet I have not heard anymore so I am assuming they are going to do it. I'll let you know and thanks for the effort.
Old Aug 17, 2017 | 01:19 PM
VTGBoss's Avatar
Thanks Bendebusk.
How difficult can it be to get a new pattern? Just take the full pattern and cut the portion close to the windshield...I would think...
I wonder if the one for the S-Type would work for the X-type? I believe that with the X-Type defroster vent cracking issue they could sell a fair number of them.
Old Aug 17, 2017 | 07:06 PM
bendebusk's Avatar
triad_ajr - I think the issue was that they did not want to try to create a pattern for another Jag model. As far as I knew (and you confirmed) they would continue selling the version they designed for me.
VTGBoss - I agree....it should be an easy thing. But I think the process of creating a new product left a bad taste in their mouth. I also agree that it could be a money-maker if they would do this for several Jag models that have the cracking problem. For them, though, it might be just a small niche.
Old Sep 16, 2017 | 10:47 AM
triad_ajr's Avatar
Ok, I got the velour pad and it fits really well on my 2003 also. Thanks again for the info
Old Sep 20, 2017 | 11:17 AM
bendebusk's Avatar
triad_ajr - I'm glad this worked out for you! I was glad to have found this "solution" and share it with others!
Old Oct 12, 2017 | 05:17 AM
Dave1963's Avatar
Thanks for the info. I will contact them to see if I can get one for my s-type. Cheers..Dave.
Old Oct 16, 2017 | 09:43 PM
davidladewig's Avatar
I just ordered one. How can you go wrong for $30.
Old Oct 16, 2017 | 10:08 PM
abonano's Avatar
My experience with dash covers is mixed.
My son's 01 mitsubishi eclipse also suffers from the cracked dash demister, however the dash is a one piece unit and I thought the Jaguar plastic was bad.
Cosmetically it makes a difference but the dash still rattles... But not spending $600 to source a replacement dash assembly.
I remember my cracked demister in my 00 S Type was soooo annoying. One crack turned into three right across the middle.
Old Oct 17, 2017 | 05:06 AM
Dave1963's Avatar
Hi mate, i have just purchased a LHS dash mat from the USA. I intend having it cut back and stitched by a trimmer to just cover the de-mister grill. That way it will still look cool and I avoid the LHS problems. It is so hard to find someone who does the RHS versions. Good luck & make sure you change the fuel filter every few years... Cheers... Dave.
Old Jul 20, 2018 | 04:34 PM
Slowglider (Slowglider)'s Avatar
Default Dash Panel Cover
Could you please tell me wherw to order that cover.
Old Jul 20, 2018 | 05:06 PM
bendebusk's Avatar
Here's the link to purchase: Dash Cover - Jaguar S Type 2000-2002 *Defrost Vent Arear Only!
Old Jul 20, 2018 | 05:53 PM
Dave1963's Avatar
Hi, here is the link I tried but they wouldn't ship it to me in Australia.
I did get one on Ebay from the US but it was poor quality.
I bit the bullet and and had one custom made by a motor trimmer.
It cost me $150 but it looks sensational and fits like a glove.
My advice..... Spend the money and get one you will be happy with... Cheers
Old Aug 28, 2018 | 12:21 PM
lderobertis's Avatar
Default X-Type
Would this work on an X-Type dash? Or are the vent locations too far off?
Old Aug 28, 2018 | 12:52 PM
Default Whoops
Sorry - I checked - they have one specifically for the X-type
