The crankcase ventilation gas V8 4.0 L
Old Dec 27, 2014 | 09:05 AM
Brayen's Avatar
Default The crankcase ventilation gas V8 4.0 L
Hi guys! Sorry for my English ))
I have a problem which I cannot solve
Some time ago I started to trickle the oil from the sensors Vano's engin v8 vanos seal.jpg
And even beginning to accumulate oil in the spark plug wells.
I ordered a new original shims under the sensors Vano's new candle rings.
After a couple of months after replacing the gaskets from under the sensor Vano's (marked in picture), began to ooze oil.
I think that there is somewhere a problem with ventilatie crankcase, oil pressure under new gaskets.
Anyone faced with a similar problem? Tell me what to pay attention.
P.S. even noticed when accelerating and pressed hard on the gas pedal, the brake pedal seemed a little pressed and when the accelerator pedal is released she also returned with a click to its original position. I think it has something to do.
Attached Thumbnails The crankcase ventilation gas V8 4.0 L-engin-v8-vanos-seal.jpg
Old Dec 27, 2014 | 09:31 AM
JagV8's Avatar
You might want first to check the fuel trims. If they are good, then you may just need new gaskets. Failed gaskets let oil seep into the spark plug wells, and the oil damages the coils.
Old Dec 27, 2014 | 09:59 AM
Brayen's Avatar
"check the fuel trims"
how can it affect the pressure in the system crankcase ?
Old Dec 27, 2014 | 10:17 AM
JagV8's Avatar
Why do you think you have that? Hint: you may not have. But if you have then the trims may be odd.
aode06
Jul 28, 2023 02:26 PM
duecedriver
Dec 25, 2015 11:47 AM
Bowman
Sep 3, 2015 03:17 PM
JagV8
Sep 11, 2013 12:02 PM
JagV8
Oct 3, 2011 03:21 PM
