Creaky Brakes - How to search the TSB's here?
Old May 19, 2010 | 09:14 PM
pdr1966's Avatar
Default Creaky Brakes - How to search the TSB's here?
Is there a TSB on 'creaky' rear brakes?
This has been getting worse, and I have searched the forums but not come up with much. Is there a good way to search throught the TSB's that are posted at the top and FAQ's?
Pete
Old May 20, 2010 | 01:10 AM
JagV8's Avatar
Try a forum search on rear brakes and if nothing relevant is found then this just isn't common (I don't think it is). I'm not aware of a TSB. If you know how to work on brakes, strip them down, clean and re-grease. Be wary of the EPB - ensure it's not applied then disconnect battery or remove fuse or something!
Old May 20, 2010 | 04:17 AM
hey there pdr....as suggested do a forum search on "creaky brakes" ...."rear brakes" etc and see what comes up. I'm pretty sure I haven't seen anything on it tbh.
Are your pads old / worn and need replaced? or are they just new?
It could be as simple as taking out the pads and smearing them with copper grease as sometimes the pads can rub to cause this type of noise!
Hopefully some of the guys will chip in with ideas / suggestions for you too....
Keep us posted
PMKimpton
Aug 3, 2019 08:22 PM
wvanepps
Oct 4, 2015 10:01 AM
Pluckie
Oct 3, 2015 07:57 AM
Jefro
Sep 15, 2015 01:44 PM
SeanU
Sep 13, 2015 02:45 PM
