"cylinder 1 missfire" problem.. I Need Help!!
Old Feb 27, 2012 | 01:52 AM
JoNRoksIT's Avatar
Default "cylinder 1 missfire" problem.. I Need Help!!
Well ive owned my jaguar for a couple months now and have to say i love it! Anyways i was driving on the highway. As i accelrrated it started cutting out a bite. Then the check engine light came on. So today i took my car to the auto store and they check for the error code. It stated "cylinder 1 missfire" so i changed the coil pack and plug but it still cutting out. Is there somethig else it could be? Do i have to take it to the dealership to get it running correctly. I know i could do this stuff to my benz and bmw without havig to take it to get the check engine light taken off.
Any help is appreciated. Thanks, JON
Old Feb 27, 2012 | 02:55 AM
Fraser Mitchell's Avatar
It would help greatly if you could tell us what model of Jaguar you have, and what engine.
Old Feb 27, 2012 | 05:15 AM
joycesjag's Avatar
Also take a trip to the "New Member" section and introduce yourself, per forum policy. You will then be granted full access to the entire site which has many many benefits.
We would ask that you put your vehicle details in your signature (use the User CP) button at the top left. This way people that are trying to help you don't have to keep asking as Fraser had to.
Welcome to the forum.
Old Feb 27, 2012 | 12:34 PM
JoNRoksIT's Avatar
Its an 01 stype with a 3.0 v6 ..
Also i will make sure to post a new member note and add the vehicle details wen im home on my laptop
Old Feb 27, 2012 | 12:52 PM
joycesjag's Avatar
edit: Norri did you beat me to the move?
back to the OP
Old Feb 27, 2012 | 12:53 PM
Michael Star's Avatar
Did you check the sparkplug as well? The coil might have been going bad for a while which might have fouled the plug.
Old Feb 27, 2012 | 01:13 PM
JoNRoksIT's Avatar
Yeah i changed the plug and coil on cylinder one and its still cuttjng out. Its odd. Ive never came across a problem likee this that couldnt be fixreed w a plug and coil pack. Jyst to make sure tho. If im looking at the engine bay from the front of the car. Coil pack # one should be on the right closest to the front or "nose" of the car correct?
Old Feb 27, 2012 | 01:19 PM
JagV8's Avatar
No. It's at the front on the right. But that is using standard car directions - which are relative to a seated driver looking forwards.
Also, see below - we NEED this info to help you:
Old Feb 27, 2012 | 02:08 PM
back to the OP
Looks like I did.
Here is the cyl numbering diagram.
File Type: pdf
Old Feb 28, 2012 | 06:30 AM
JoNRoksIT's Avatar
Ooo.. So i need to replace the one under the under the intake manifold.. Where i got my previous info said that it was on the drivers side. Haha glad i came here. Thanks for everyones help and im sure ill be back again!! Thanks, Jon
PhilXJ6
Jan 3, 2016 08:55 PM
Delta66
Oct 4, 2015 05:40 PM
sandmann62
Oct 1, 2015 09:31 AM
baskervillema
Oct 1, 2015 01:59 AM
