dealership mixed my oil
Old Apr 1, 2009 | 07:37 PM
phaelax's Avatar
Default dealership mixed my oil
Finally got my car back, took them over 2 days to replace the cam gaskets which caused an oil leak damaging one of my coils. On the invoice when I picked up the car it said the added 2 quarts of oil, which they didn't mention to me. I asked what oil they used and they responded by saying my car can use either regular or synthetic but I had regular so thats what they put in. I had to correct him, I used royal purple synthetic with my last oil change and now they just mixed in 2qt of non-synthetic. So is there anything I need to worry about? I've also heard that once you start using synthetic you shouldn't go back to non-synthetic. Also, do you think they should have to pay to drain and replace my car's oil with the synthetic brand I was already using?
Old Apr 1, 2009 | 08:42 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
If you have your receipts for the syn oil, you'll be in a better position to have them do the change..or if the dipstick can show the "right color", it should also help.
Good luck.
Old Apr 1, 2009 | 10:10 PM
rianbechtold's Avatar
It's a wive's tale that you can't mix the two, what do you think a "Synthetic Blend" is?
It will not hurt a thing and no they should not drain your oil and replace it with the synthetic, it is just a top off. It's no different then taking your car to a dealer and they "top off all fluids."
Old Apr 1, 2009 | 10:17 PM
Brutal's Avatar
its no problem, but why didnt you tell them you have synthetic before hand
Old Apr 1, 2009 | 10:21 PM
JagtechOhio's Avatar
Ryan, did you have any luck scrounging for your missing pieces?
99xk8guy
May 28, 2024 09:36 PM
njburlington
Sep 24, 2015 08:40 PM
Tim Goz
Sep 17, 2015 09:11 AM
ferraripete
Sep 16, 2015 03:42 AM
teacoff
Sep 10, 2015 08:25 AM
