Defrost/Heater - 2000 S-Type
Old Jan 8, 2015 | 09:36 AM
G_Stype's Avatar
Default Defrost/Heater - 2000 S-Type
Heater/Defrost blows cold. What would cause this. I just changed the thermostat and it still blows cold when I trying to change to heat mode.
there must be a sensor or valve that not allowing fluid through the heat coil.
needing help.
Last edited by GGG; Jan 8, 2015 at 09:53 AM. Reason: add Model and Year to thread title
Old Jan 8, 2015 | 09:52 AM
Welcome to the forum G-Stype,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Jan 8, 2015 | 10:36 AM
JagV8's Avatar
DCCV stuck closed? Zillions of threads you can read already on here.
Old Jan 12, 2015 | 03:44 AM
Paul792's Avatar
This link might be a starting place for you.
DIY: Diagnose It Yourself - JaguarClimateControl.com
But as JagV8 mentioned above there are a lot of discussions posted on the forum and it is a common problem with a number of related issues. For instance: when the heater valve gets old and deteriorates it can effect the climate control board.
3jagfamily
Oct 1, 2015 01:49 AM
moff1959
Sep 26, 2015 05:35 PM
