Diagnosing Current drain / Battery going flat
Old Jun 4, 2014 | 01:35 AM
JagV8's Avatar
Default Diagnosing Current drain / Battery going flat
I got to thinking about a way to find which circuit is drawing current after the 30-40 mins by which time the car is meant to have gone fully to sleep (apart from about 50mA for any alarm and the like).
The "traditional" way uses a meter on amps/mA in series but the problem is where to put it and that you can't move it to a different circuit without restarting the 30-40 mins.
I figured a fuse is a small value resistor. So, put the meter on mV (millivolts) across the 2 terminals of the fuse.
I figured this was "too easy" and would by now have been mentioned on here if it worked but decided to try it anyway - and it works!
It's very easy and fast to do so it also means it's reasonable to ask another owner to see what theirs reads when you find a suspect mV reading (i.e. a suspect circuit).
And then... knowing what terminology I might use to describe this (fuse voltage drop, battery drain) I did a web search and of course someone's discovered this technique already, such as:
A new approach to testing parasitic draw | Search Autoparts
Oh well. It's still useful.
Old Jun 4, 2014 | 01:51 AM
plums's Avatar
Is the technique not really a variant of the classic "voltage drop" measurement used to look for resistance in connections?
It works because the drop varies with current, so a circuit drawing higher current will show a higher voltage drop across those terminals. The terminals on the fuse act as a "standardised" circuit segment for each fused circuit since the terminal spacing is the same on all of the blade fuses.
Old Jun 4, 2014 | 02:05 AM
JagV8's Avatar
It is, but I'd never heard of it in the context of looking for battery drain in a car. I don't recall it ever mentioned in all the threads here where people have hunted desperately for the bad circuit(s).
I "invented" it by wondering (not in connection with a car or a fault, just one of those wondering things) how low a resistance a fuse was (it had to be non-zero or it wouldn't ever blow) and then made the little mental leap to thinking it could be used this way.
99xk8guy
May 28, 2024 09:36 PM
Jandreu
Jun 30, 2022 03:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
obwoodie
Sep 3, 2015 07:45 PM
