differential lubricant
Old May 15, 2017 | 11:00 AM
jagrov's Avatar
Default differential lubricant
specification and capacity
Old May 15, 2017 | 04:17 PM
Mikey's Avatar
Year?
Old May 15, 2017 | 04:21 PM
JagV8's Avatar
Is it in JTIS? JEPC? Both are free.
Files uploaded here?
Web sites? Yes, probably those as well.
All good places you can look.
Old May 16, 2017 | 05:30 PM
Don B's Avatar
Hi jagrov,
Welcome to the Jaguar Forums.
Please visit the https://www.jaguarforums.com/forum/n...-intro-must-5/ and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
And please let us know the year, model and engine of your Jaguar so we can offer accurate replies to your questions.
Cheers,
Don
Old May 17, 2017 | 05:46 AM
cat_as_trophy's Avatar
New game seeking info, but offering as little as possible. Whose turn now?
Ken
Old May 18, 2017 | 05:26 PM
swingwing's Avatar
Capacity on 2003 STR is 2.7 pints of synthetic 75W-140, which is a smidge over 1 quart or 1 litre. My choice of oils and lubes is AMSOIL. Sold me X-Type but am now looking at an STR.
Attached Thumbnails differential lubricant-tools-2017_05_17-17_18_51-utc-.jpg
Old Jun 2, 2017 | 01:55 PM
Catmobile's Avatar
I've found that Mobil1 75-140 synthetic is a good choice, I called them and was told it will work fine. Jaguar uses Castrol 75-140, but I've only seen it in five gallon buckets, a bit much for me. The Ford Spec 75-140 is $30.00 a quart at my local dealer and Mobil1 is $20.00 locally, so I went for that. They're all similar, I believe. Don't use regular 75-140, It's stamped right on the rear end to use synthetic fluid. Don't ruin your car for a couple of bucks. There's no drain plug so the old fluid has to be sucked out. Many lube places and garages have devices to suck out the fluid, if you don't want to buy one. I've found that making a 90 degree bend in a foot or so of 3/8 tubing works great to stick in there and get to the bottom. Much better than just vinyl tubing.
The same for transmission fluid use ZF fluid LifeGuard6, that's what is in a six speed trans. Don't mix something different with it. At Genuine ZF Parts it's like $20.00 a quart, why use anything else? Compared to what you spend on gas and insurance, fluids are a drop in the bucket.
King Charles
Jul 3, 2017 06:50 AM
Sleepnever
Apr 30, 2017 08:08 PM
al_roethlisberger
Apr 19, 2017 08:02 AM
Jag-Nut
E type ( XK-E )
Mar 17, 2017 09:27 AM
CarGuy
Feb 23, 2017 03:45 PM
