disconnecting drl's help
Old Feb 7, 2009 | 11:42 PM
v8stype's Avatar
Default disconnecting drl's help
Is there anyway of disconnecting the daytime running lights, because im trying to install hid kit on headlights and they only work if my car is not on and once you start it only one headlight works? i have halogen headlights
Old Feb 7, 2009 | 11:48 PM
JagtechOhio's Avatar
Greetings,
My understanding is that the DRL is a programing function which can be set with WDS or IDS at a dealer or independent with the equipment.
jag_genius, BRUTAL, or Real_Tech will be able to tell you for sure, one of them should be stopping by in 12 hours or so.
Old Feb 8, 2009 | 10:25 AM
searanch's Avatar
Cool
When I imported my STR from the US to Canada I had the dealer hook it up to a laptop and he turned them on in the same way he will turn them off for you. Took less than five minutes...
Old Feb 8, 2009 | 10:34 AM
jag_genius's Avatar
yep has to be done thru ids or if you live near me .. i have my own ids
Old Feb 8, 2009 | 11:32 AM
v8stype's Avatar
thanks alot for your help guys,jag_genius i live in las vegas
philwarner
Jan 31, 2016 09:36 AM
Dave1109971
Dec 15, 2015 06:16 PM
Rocky15
Oct 12, 2015 03:42 AM
Collector1
Sep 28, 2015 03:52 AM
