do i need spring compressor to remove rear shock absorber ?
Old Jul 10, 2015 | 03:15 AM
tibam13's Avatar
Default do i need spring compressor to remove rear shock absorber ?
hello
i have to change my bushings at the lower end of my rear shock absorbers, but shocks absorbers and spring are quite good enough to avoid being changed too, so i'd like to know if i need a spring compressor or not ?
the front end shocks did not need any spring comp when i removed them (shocks + spring in the same part) in order to change my vertical link.
thx !
Old Jul 12, 2015 | 05:18 AM
Paul792's Avatar
I have not replaced the shocks on my Jag. But I have on two other cars that required a spring compressor. I used a cheap spring compressor as I don't often replace shocks. However they can be dangerous if they slip off the spring under pressure. So it is good to be cautious.
Below is a quote from QuartzSTypeR and the link for this is below in post number 7.
Originally Posted by QuartzSTypeR
They are not all that difficult to do if you have all the tools and are careful not to stretch the brake lines. I believe I needed a 55 or 60 torx bit for one of the bolts and you will need a spring compressor. As far as brand, the only ones I would recommend for regular driving are the Bilstein Sports as mentioned above. You can probably get something cheaper like Monroe Sensatrac, but the ride will be soft and unsatisfactory.
https://www.jaguarforums.com/forum/s...acement-94639/
I hope this helps.
Old Jul 17, 2015 | 09:15 AM
aholbro1's Avatar
You don't need one to accomplish the intended task on the 2003 & subsequent cars. I'm sorry, but I'm unfamiliar with your particular model, though I am certain the suspension was one of the major changes for the 2003 refresh.
Old Jul 17, 2015 | 03:32 PM
Tijoe's Avatar
Undo the shock from the lower control arm. Open the trunk and move the carpet out of the way to get access to the 4 nuts that hold the shock/spring assy. (coilover) in place. Remove the nuts and the whole unit can be removed. You probably can fit the lower part of the shock into a press or the puller that you use without having to remove the spring. But if your shock bellows is rotten and/or the upper shock mount rubber and bearing are bad, you will need a spring compressor to remove the spring from the shock. The upper mount assemblies are still available at not too bad a price.
Old Jul 17, 2015 | 05:28 PM
davidladewig's Avatar
How about trying it this way before you jack her up? Hmmmm!
Old Jul 18, 2015 | 08:36 AM
Tijoe's Avatar
LOL. Not to sure if you are serious or not. He should just go to Auto Zone and borrow a coil spring compressor for free.
The coilover spring is actually under a lot of load being that it is compressed about 3/4"
Best to use a spring compressor.
Attached Thumbnails do i need spring compressor to remove rear shock absorber ?-rear-chock.jpg   do i need spring compressor to remove rear shock absorber ?-top-shock.jpg
Old Jul 18, 2015 | 09:41 AM
[QUOTE=Tijoe;1269464]LOL. Not to sure if you are serious or not. QUOTE]
It was joke.
Old Jul 19, 2015 | 03:58 PM
leaping cat's Avatar
The answer is: no, you do not need to worry about the spring at all.
KarimPA
Sep 12, 2015 08:15 AM
davidladewig
Sep 3, 2015 06:32 PM
Busa R
Sep 3, 2015 05:01 PM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
