Doing the Timing STR... Timing Tool removal??
Old Mar 24, 2011 | 08:40 PM
mystype04's Avatar
Cool Doing the Timing STR... Timing Tool removal??
Im doing the Timing in my STR and I dont have a working JTIS.
So far I have it all done, but all I need is the last few steps... And just in case, "yes" I'm using the Jaguar needed timing tools.
In other words should I remove the Cam timing tool (holder), before tighting the CAM gears? Or should I tighting them before removing the Timing CAM (holder) tool?
Whats the Sequence???
Thanks,
JG
Old Mar 24, 2011 | 08:46 PM
vance580's Avatar
Wow go you. What did you have done that you have to set up the timing? Did you do some head work? Anything performance wise or did you break something?
Old Mar 25, 2011 | 09:00 AM
mystype04's Avatar
Smile
vance580,
The car overheated without any warnings. The Temp needle never even moved above half way (weird)... I had a leaking returning line wich connects to the coolant resevoir... Well I replaced the Head Gaskets and
  • The machineshop did a Valve job, and also shaved the heads .010
  • I ported the Headers. Now I have about 1Lb (from metal shavings), or maybe even more? (done)
  • I have high flow CATs and 2.5" 45degrees bends that I bought...
  • I'm planing in a Cold air intake. (very soon)
  • 3Lbs Pulley intalled already (done)
  • Ported and polished the SC (done)
  • Crossed drill Rotors (soon), whenever I get around doing my brakes (next!)
JG
Old Mar 25, 2011 | 10:27 AM
Brutal's Avatar
You do not remove the tools until everyrthing is done. You do pull the grenade pins before tightening the sprockets to put the tension on the correct side or timing will be off. And you need to hold the sprockets stationary while tightening
Old Mar 25, 2011 | 02:02 PM
mystype04's Avatar
Thumbs up
Thanks Brutal, just what I needed!
JG
Old Mar 25, 2011 | 02:21 PM
vance580's Avatar
Originally Posted by mystype04
vance580,
JG
Sweet cant wait to see what you think of the mods. You gonna do a dyno? Also I should of worded my question better after I re-read it. I meant to ask if you did any mods to the heads or did you just remove for the head gasket then have them resurfaced? Or did you do any porting valve jobs etc to the heads?
Old Mar 28, 2011 | 03:59 PM
mystype04's Avatar
Wink
vance580, yes I just did a regular Head Gasket replacement. I was very tempted to do some grinding and polishing, but I have done it in the past (in my Northstar Fiero), and it is quite a bit of work... So for what is worth I do have a bit more compression, since the heads were shaved .010. Although I have to say there was enough carbon build up throughout the whole intake system: Intercoolers, TB, intake runners, Valves and SC, all in general it was very contaminated with carbon. But the car did feel powerful then; I just think that now it will feel even better! Whoever had this car was using very cheap gas. Even the pistons were clogged…
LOL, most likely I did gained some HP with the just the cleaning alone!!! Aside from the possibility of the previous owner using cheap gasoline, what I found more interesting was to know that this is a “true” prove that these cars do run with a rich mixture of gasoline from factory. Without a doubt it is probably to keep the engine temperatures safe and the detonation away. This is why we all can upgrade: Exhaust, intake and pulley without tuning.. =)
JG
Old Mar 28, 2011 | 06:12 PM
vance580's Avatar
JG
Nice great info.
Old Mar 29, 2011 | 08:54 AM
mystype04's Avatar
Thumbs up
Originally Posted by vance580
Nice great info.
Old Jan 15, 2024 | 06:28 PM
Mike 8897's Avatar
Default Timing
You'll need the timing kit to time the motor . The heads and flywheel should be locked and tensioner have pins in them. There is a special tool to hold the exhaust gear in place to tighten the bolts up. According to the workshop manual those bolts HAVE TO BE REPLACED . you can buy the kit on eBay .
Old Jan 15, 2024 | 07:11 PM
motorcarman's Avatar
13 years is along time to advise...
I would guess the problem is sorted by now?
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
