DSC fault/ Brake noise
Old Jul 25, 2018 | 09:23 AM
Uno Strzelichowski's Avatar
Default DSC fault/ Brake noise
hi as if fixing an AC wasn’t hard enough another problem came up; should’ve expected from jags. So few weeks ago I replaced the driver side calipers. I bled that brake but I did not on the other side. Now, the brake I replaced makes a weird rubbing noise when I break softly but when I brake hard, it does not. Will this interfere with DSC fault or is there something wrong with the sensors? If yes, where should I start looking for the issue?
Old Jul 25, 2018 | 10:21 PM
Datsports's Avatar
and any other brand of motor vehicle too for that matter .
mine has never had the issues your explaining so why should i expect this ?
you need a scan tool that can read chassis codes , (C codes ) it will likely point strait at the issue with its stored codes .
and help with your attitude you are having with your car .
an Icarsoft i930.JLR scan tool will most likely be your best bang for buck .. and should do the job .
if you are not confident using scan tools . find some one who is and let them do it for you.
Old Jul 25, 2018 | 10:54 PM
scottjh9's Avatar
I agree with datsports on the i930. I have one and i love it. Very simple to use and understand. It has a help feature that explains the codes and possible causes. Dont give up on your car....it is a valueable and rewarding learning curve at first..plus here on the forum you have all the help and knowledge you will need
Old Jul 26, 2018 | 09:10 AM
Staatsof's Avatar
Bleed the entire braking system then see where you are.
cincinnati
85
Jul 31, 2018 10:47 PM
ford289ci
62
Sep 28, 2015 08:37 AM
talashek
Aug 9, 2012 01:32 PM
45Wheelgun
Oct 5, 2011 03:44 PM
bodytech
Mar 9, 2011 07:59 AM
