emergency brake question
Old Aug 22, 2014 | 02:38 PM
hilaryv215's Avatar
Default emergency brake question
Hi everyone,
O I had my gear shifter cam replaced, I was told to prevent from getting stuck again pull emergency brake on than shift to park,MY PROBLEM I LIFT THE 911 BRAKE N NOTHING DOESNT STAYUP....
Old Aug 22, 2014 | 03:25 PM
Chase6495's Avatar
Originally Posted by hilaryv215
Hi everyone,
I just needed to have the cable tightened. It's a quick fix (my mechanic did it for free). If not that, then I don't know what the problem would be. Check that out and update with what you find.
Old Aug 23, 2014 | 09:34 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Hi everyone,
On my '01 we need to pull the lever quite high before the ratcheting mechanism engages and the emerg brake begins to hold. Perhaps you're not pulling it high enough before giving up?
But as mentioned above, sounds like both of us could use a cable adjustment.
Old Sep 9, 2014 | 08:12 AM
hilaryv215's Avatar
ok so update, the brake when lifted shows on the screen so its not cables its the hand brake itself just not clicking to stay up, just falls down, help!!!!
Old Sep 9, 2014 | 08:28 AM
JagV8's Avatar
Sounds like need to adjust or replace the cable.
Forcedair1
Sep 8, 2025 01:57 PM
Razor
Aug 28, 2019 08:34 PM
PMKimpton
Aug 3, 2019 08:22 PM
James007
Oct 3, 2015 03:29 PM
James007
Sep 6, 2015 06:47 PM
