engine code p1383?!
Old Feb 2, 2015 | 07:52 AM
hilaryv215's Avatar
Default engine code p1383?!
P1383 on jaguar s type?
Old Feb 2, 2015 | 08:19 AM
JagV8's Avatar
Look in JTIS / codes PDF / use forum Search
Old Feb 2, 2015 | 11:49 AM
hilaryv215's Avatar
Thank u . um I checked it and I'm confused on what exactly is wrong and I called jaguar and they didn't give me an answer they pretty much said they weren't sure unlessnibbring it in.... I just want to be prepared for damage so I know to say I give up or fix.... I'm $5000 in on a $4500,car
Old Feb 2, 2015 | 12:42 PM
joycesjag's Avatar
Don't know why the search result page does not show correctly.
GoTo:
(click) SEARCH
(click) Advanced Search
in "Search by Keyword" type P1383
in "Search in Forum"type S Type
(click) Search Now
Two pages of results will appear.
Old Feb 2, 2015 | 12:45 PM
hilaryv215's Avatar
Lol well jagv8 I'm very good girl but I am polish so help is needed
Could you please help me.
I can give u a quickie rundown
I am about due for oil change I do have a leak and when I checked my oils empty practically now.
That being said for the first time with engine light and code p1383 it went a little over on the c/h temp thingy in my dash
Now my understanding.... Please tell me if I'm wrong.
I can engine flush and complete oil change and have a chance?
Old Feb 2, 2015 | 12:49 PM
hilaryv215's Avatar
Oooo 2002 s type 3.0 6 cy
Old Feb 2, 2015 | 02:38 PM
JagV8's Avatar
Much faster to read the existing copious detailed info. Why on earth would anyone retype it???
Old Feb 2, 2015 | 09:39 PM
abonano's Avatar
Related to VVT (variable valve timing) solenoid
Old Feb 3, 2015 | 01:28 AM
hilaryv215's Avatar
Well #1- the info that came up half of it doesn't make sense. Second no one gave a real experience on it I went on jf search n typed p1383 and what aame up was not before that
Old Feb 3, 2015 | 06:06 AM
joycesjag's Avatar
All above posts make sense.
I came up with 2 pages of results for "P1383" yesterday and this morning. I do not know why my link did not goto the result page, sorry. I did show you how to "search" though instead.
Old Feb 3, 2015 | 08:18 PM
abonano's Avatar
lots of info on the forum.
Mainly due to lack of oil change maintenance. Do this: purchase engine flush - run engine (from cold) at idle for about 20 to 25 mins, drain oil.
Put in conventional cheapest oil you can find (5w20 viscosity) and I mean cheap like auto big box branded oil like advance cause your gonna change it after 1,000 miles.
Here's the trick - sub 1qt of oil w/ Mercon 5 transmission fluid. Trans fluid is highly detergent and will penetrate and clean the small oil passages of the VVT solenoids.
It takes about at least a few hundred miles of normal driving.
The above method is proven.
Also there is a TSB for VVT's for the 3.0 engine that is remedied by reprogramming.
Old Feb 4, 2015 | 06:27 AM
I suppose the hood is opening now?
Old Feb 4, 2015 | 07:49 AM
joycesjag's Avatar
Supposing is better than assuming!
Old Feb 4, 2015 | 11:49 AM
hilaryv215's Avatar
Well I went to advanced auto when I was done at mechanic and the guy showed me how to pop the hood manually. My passenger lever is bent :/ apparently from a accident and sdamage to that side....
Anyhow yes I can open it now!
Old Feb 4, 2015 | 11:51 AM
hilaryv215's Avatar
So I readeverything i could on here took abonanos advice and took to mechanic had a engine flush and oil change than changed my other fluids out myself and light is still on but only drove 20 miles but no lag in driving and not over heating so thank you
I did take pics of how to find the latch if there's anywhere to post em in case any other pollocks can't figure it out
Old Feb 4, 2015 | 11:53 AM
hilaryv215's Avatar
Um down side.... Lol mechanic broke my grille so I'm looking for a replacement but not a big deal
Old Feb 4, 2015 | 07:28 PM
abonano's Avatar
Did the mechanic sub 1qt of oil for ATF?
Old Feb 5, 2015 | 11:58 AM
hilaryv215's Avatar
Abonano -
I don't believe so according to my paper work its says professional engine flush -$89.95
Oil change 10-30 5 qt n filter. $79.99
Nothing about that stuff.... Is that something j should buy and throw in anyway?
Old Feb 5, 2015 | 12:00 PM
hilaryv215's Avatar
****abonano for reprogramming youre meaning..... Resetting computer code?
Old Feb 5, 2015 | 05:09 PM
abonano's Avatar
Please read up on the forum - lots of info and $80 for an engine flush? Again, I was trying to offer you a proven solution that has helped many fellow members in the past. Unfortunately, you threw $160++ at a problem that may not yield a suitable solution.
You need to get a reflash of the PCM via a dealer level dial agnostic machine if it was not done previously. jaguar can tell you if your vehicle has been serviced for the TSB.
