External temp sensor location
Old Jul 17, 2007 | 08:42 AM
rivs's Avatar
Default RE: External temp sensor location
it is by the radiator you need to remove the radiator splash shield, and then the rad lower cowl.So your sensor may well be touching the radiator I'd guess
Old Jul 23, 2007 | 02:47 AM
12RM's Avatar
ORIGINAL: khezik
[sm=badbadbad.gif]Hi all,
I did a search for this but was only able to find results for the X-type. My 01 3.0 S-type keeps registering an external temp of 127 degrees F. sometimes if it sits for a while it'll read 125. I'm assuming its the external temp sensor but I have no idea where its located.
I'm wondering if its loose and maybe dangling in the engine compartment hence registering such high temps and slightly lower when the car sits for a bit.
On the X-type its located near the front tow hook but I couldn't find it on the S. Any help is greatly appreciated.
Thanks!
Alex
The external temp' sensor can be found by looking up from under the front number plate, it's located on the back of the beam at the front of the car. The device is shaped like a spark plug and you will see the bottom of it which is cone shaped. Just pull down to remove it from the connector, £5 from the dealer.
My car had the same fault, high external readings, seems it's a common fault.
Hope this helps.
Donzi
Oct 18, 2018 12:26 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
KarimPA
Sep 12, 2015 08:15 AM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
KarimPA
Sep 3, 2015 07:32 PM
