fan blows cold only
Old Jun 20, 2014 | 08:25 AM
phildog's Avatar
Default fan blows cold only
hi all first post hope its in right place my car 2.7 stype diesel auto 2005
turn up temp to full still blowing cold air from both sides have bled cooling system prob still remains.with expansion tank lid open if i pinch hose on rhs (the big one lower than tank not small one on top)nothing happens to the level in the tank think this means no coolant in it if this is so how to get coolant to this hose which hopefully will then feed heater.not that good with these things so idiot proof instructions would help thanks in advance.
phil
Old Jun 20, 2014 | 08:31 AM
pitifulpluto's Avatar
I recommend getting a radiator cap pressure kit.
It will help you push all of the air out of the system to get the correct coolant level.
As for not having a working heater, it could be your thermostat is stuck open and not allowing the engine to get hot enough for the heater to work.
Does you car reach operating temperature? Or does it run a bit cold?
Old Jun 20, 2014 | 08:38 AM
phildog's Avatar
this is all new to me temp gauge go,s up to one third is this where it should be?
Old Jun 20, 2014 | 08:49 AM
That seems low to me.
Is there any way for you to get an exact reading of the temperature?
Any generic obd-2 tool should give you an exact temperatue reading.
With diesel engines they will run quite cool with the thermostat stuck open. This is not very good in the long run, but don't worry about running it for now.
Old Jun 20, 2014 | 08:55 AM
phildog's Avatar
dont have any tools like that.i do know the water is hot enough to take your skin off
jazzman20014
Oct 26, 2015 04:15 PM
swetnK
Sep 23, 2015 10:49 AM
Tipptone
Sep 16, 2015 07:39 AM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
