FOB Alarm problem?
Old Nov 1, 2013 | 11:15 PM
jpeterson1973's Avatar
Default FOB Alarm problem?
I have an 2000 S-type 4.0L Jaguar. If the car has sat for an hour or more then the FOB will not disengage the alarm or unlock the doors. I have to open the drivers door with the key, then the alarm will go off and then I can use the FOB to disengage the alarm. After this then the FOB will work normal, unless the car has sat for an hour or more(I think. I only know that after I engage the alarm at night then go out in the morning this happens. I usually do not lock the car while at work.). This started happening at the same time I had a check engine light come on. The code is: P1633. I have been told that this has something to do with the ECM unit. I have also been told that there is another module that deals with the door locks that could be the problem. A few other things that started when this happened are: electric mirrors will not adjust and drivers seat will not adjust. Other that these things the car drives fine and starts fine.
Old Nov 2, 2013 | 02:56 AM
JagV8's Avatar
First thing is you can stop alarm going off if you unlock door with key and quickly put key in ignition. (Well, it does on later cars - never had one like yours to play with.)
Codes are in JTIS and codes PDF - both free download on here.
P1633 is a lack of constant power to the PCM. Probably your battery is near dead but also check in case water in trunk (check under spare).
The other things also sound like a lack of power.
Old Nov 2, 2013 | 09:13 AM
police666's Avatar
Turning ignition on will turn alarm off on the early cars
Old Nov 3, 2013 | 09:02 AM
The battery would not hold a charge and I put a new one in. The problems still are there. Thanks for the help.
Old Nov 4, 2013 | 12:47 AM
Diamondrmp's Avatar
Although not exactly the same problem you have my fob stopped working completely today. So I found a reset on here. Check out response #5 and try the procedure. It worked for me and my FOB is working perfectly.
https://www.jaguarforums.com/forum/x...orking-100457/
Rick Michael
Sep 6, 2015 06:53 PM
Bigvettefreak
Sep 6, 2015 04:27 PM
My Pham
Sep 4, 2015 03:37 PM
philwarner
Sep 3, 2015 10:14 PM
laserguy
Sep 3, 2015 02:02 PM
