Ford 5R55N Refuses to engage
Old Mar 3, 2013 | 12:52 PM
thebiglad's Avatar
Originally Posted by josvantbos
Before tackling a gearboxswap, is there someone who can assure me that you can disassemble the gearbox from the engine? I can't figure out how to loosen the top bolts from the gearbox housing which attaches it to the engine....
Very easy. You take the top bolts out first, via the inside once the centre console is removed.
You need to be able to pivot the engine gearbox assembly by removing the propshaft, gearbox mounts, now allow it to pivot down enough until you can access the top bellhousing fixings.
Once you've got those out, then remove the rest.
Old Jun 7, 2013 | 01:42 AM
Gelo Garcia's Avatar
Hey guys! I've working on a 2002 Jaguar S-Type. Is there a specific programming or road test sequence i need to complete after swapping out the tranny? Thanks
Old Jun 7, 2013 | 08:26 AM
JagV8's Avatar
Don't think so but drive cycle is in codes PDF in stickies & JTIS - both free download.
Old Oct 12, 2013 | 10:49 PM
emagos's Avatar
Default Wow! Can't believe I came across this thread
Thanks josvantbos for saving me from making the same mistake. Getting ready to reinstall main valve body after installing spring kit. Like you, don't think I would've remembered to seat the gear lever pin to the valve properly. 'Appreciate your post. Thanks again and good luck. Hope your tranny is holding up well. R/Manny
Old Oct 31, 2013 | 07:16 PM
miteaman's Avatar
ps prime the pump on the r5 or it will go bang.
Old Nov 1, 2013 | 01:43 PM
volor's Avatar
Would be grateful for a copy of the 5R55N Technical Paper, if someone has it... Doing Gearbox Oil change on my V8 this winter Email address is living.fossil62@gmail.com Thanks in advance
magmedia
Oct 8, 2015 03:28 PM
millertic
Sep 30, 2015 08:11 PM
redxk8
Sep 30, 2015 08:18 AM
