Front lower wishbone replacement
Old Sep 9, 2022 | 03:05 AM
davivern's Avatar
Default Front lower wishbone replacement
The front bushing on both sides of my 2001 S Type 3L petrol (VIN 3277590053006L40904) front lower wishbone are worn out. Can anyone give me some guidance on how to remove and replace please.
Old Sep 9, 2022 | 10:49 AM
NBCat's Avatar
Assuming you have the necessary tools, remove the road wheels, brake calipers and discs, and the retaining nuts from the upper and lower ball joints. Next remove the suspension uprights from the upper control arms and lower arms.
Remove the three bolts securing the steering rack to the front crossmember and lower the steering rack to allow removal of the lower control arm rear bolt.
Reassembly is in the reverse order. Remember to reinstall the lower control arm bolts with the threads facing towards the front of the vehicle. Use anti seize compound on bolt shanks to allow for easy future removal. Install new nylon lock nuts if available and torque to correct specs with the road wheels installed and the vehicle on a level surface.
Old Sep 9, 2022 | 11:57 AM
NBCat's Avatar
@davivern, when removing the bottom bolt from the strut assembly, inspect the bush as it's a know wear item.
Here is a link to the X200 Workshop Manual PDF:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Old Sep 11, 2022 | 02:04 AM
davivern's Avatar
Thank you very much
Redjags
May 29, 2022 07:24 AM
jomo
Oct 15, 2021 08:21 AM
Peterinio
Jun 7, 2019 09:05 PM
obi717
Mar 20, 2018 11:14 AM
edadoune
Aug 16, 2017 03:10 PM
