Gas cap leak
Old Jan 13, 2016 | 02:35 PM
hifipm's Avatar
Default Gas cap leak
I had the check engine light come on- code P0456(I think) very small evaporative leak-checked the gas cap and it would no longer lock on - ordered a new one and it also does not lock so I am thinking it might be a problem with the filler tube-anyone had this issue? Thanks
Old Jun 28, 2016 | 11:24 AM
pab's Avatar
pab
Same thing happened to me last year. Check gas cap light came on and wouldn't stay off.
My local mechanic replaced the cap and it has been fine for about a year. This past weekend the light came back on and is now behaving like it did last year.
Anybody got any ideas for why a gas cap seems to have only sealed for a year? Or did the new cap mask some other underlying problem?
Jaguar: Grace, Pace, and Space - Sir William Lyons
2015 JCNA National Slalom Champion Class M
Current: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
Old Jun 28, 2016 | 12:35 PM
Mikey's Avatar
The most common cause for P0456 is not the gas cap.
Old Jun 28, 2016 | 03:10 PM
pab's Avatar
pab
Ok, my yellow warning light is on and the message displayed is "Check the Gas Cap", so this might be difference.
Jaguar - it's not an automobile, it's a Motorcar
Current: '08 S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Old Jun 29, 2016 | 07:40 AM
pab's Avatar
pab
Stopped by my local mechanic this morning and he used his code reader to see a P0456 code (displayed as "small evaporator leak" or something like that), so that is the cause of my "Check Gas Cap" warning.
Does anyone know what's the most usual cause of that code?
You dreamed of a big star -
He played a mean guitar -
He loved to drive his Jaguar...
So welcome to the machine
Old Jun 29, 2016 | 08:58 AM
Mikey's Avatar
Quick search reveals dozens of threads including this important one
https://www.jaguarforums.com/forum/s...76/#post277647
This is what I was alluding to with it's 'not the gas cap', at least with my car.
Old Jun 29, 2016 | 10:41 AM
pab's Avatar
pab
>P0456 Evap Small Leak - But not really?
Yes, and in surfing around today this is what I have come up with (and it agrees with "kit" replaced in the link above:
From: https://www.jaguarforums.com/forum/x...de-p0456-6423/
Code: P0456
Do the gas cap first
if after that you still have an issue it may verry well be a canister close valve
if you end up doing the CCV make sure you replace the pipe as well
it runs between the 2 charcoal canisters
the pipe is usually the culprit due to moisture and then rust
that rust ends up getting into the CCV valve and keeps it from closing completely
I recently had the same issue, although my code was PO455. Tried the Gas Cap first to no avail. The new Canister and upgraded Vent Tube Kit took care of the problem completely. All in all, it wasn't too bad.
P0456 OBD-II Trouble Code, Evaporative Emissions - Jaguar
MOST LIKELY CAUSE:
First of, if you haven't already change the fuel cap.
Then just clear the code and see if it comes back. I changed countless fuel caps over the years.
If that doesn't work, you might want to look at the canister close valve and the canister purge valve. This are very common as well.
dhog4n
Dec 31, 2015 09:31 PM
philwarner
Dec 29, 2015 10:21 AM
SickRob
Dec 24, 2015 04:24 PM
x42bnx
Dec 23, 2015 07:45 PM
davecabezo
Dec 16, 2015 08:28 PM
