gas smell
Old Nov 20, 2024 | 03:48 PM
BLACK CAT BOB's Avatar
Default gas smell
I have a new to me 2005 S type R . When I start the car and turn the A/C or heater on I get a gas smell , and since the air intake is close to the fuel lines I suspect a leak some where . Any advise on what I should look at first . I bought some dye that I am planning to put in the fuel tank hoping to find where the leak is.
Old Nov 20, 2024 | 11:13 PM
Peter_of_Australia's Avatar
First obvious step: Look under the car, especially after driving, if you see somewhere fuel dripping out - maybe even a puddle of fuel.
Obviously, if fuel is indeed leaking, that is a huge fire danger - I suggest that you don't drive that car until you have a fire extinguisher accessible in your car for "quick excess".
Apart from that, I'd start by swapping the fuel filter, which is always a good idea. The brand "WIX" is good.
Old Nov 24, 2024 | 05:01 AM
While looking for something else on youtube, I came across this - maybe it helps...:
Old Nov 24, 2024 | 09:52 AM
Thanks for the info . I did put it on the lift and removed the driver wheel well liner to inspect the fuel filter , no leaks but I am going to replace the filter before it goes back together . I did look at the fuel lines that are visible didn't see anything . The supercharger and plenum make it hard to see the injectors but that is what I am going to focus on next . I have 3 projects cars going now so I bounce around working on them .
Old Dec 23, 2024 | 09:32 PM
dlnga's Avatar
Exclamation Fuel leak
I had the same issues a few years ago with my 2005 S Type R. Found out that there was a recall in 2007 for all S Type R's for a faulty fuel tank. With some research I was able to locate documentation that the previous owner complied with the recall and Jaguar fix the problem free of charge. Fast forward about 5 or so years ago and I started smelling gas but no signs of a leak. My mechanic was able to find the leak and it was basically the original 'fix" had worn out and the initial problem had returned. I wish I had contacted Jaguar back then to see if they had any recommendations to fix the leak. That repair cost me over $3400.00! I love that car but I'm smelling gas again and I'm thinking it might be time to take her out back and shoot her. Hope you have better luck with yours.
Last edited by dlnga; Dec 23, 2024 at 09:35 PM. Reason: needed to add date of recall.
hueyhoolihan
84
Oct 18, 2022 05:38 PM
Iconoclast
Feb 1, 2021 01:56 AM
ageyev
Apr 29, 2020 01:52 PM
chip
Dec 2, 2014 10:50 PM
