Gear Shift problem
Old Jul 24, 2013 | 07:53 AM
rwold's Avatar
Default Gear Shift problem
My 2004 S-type will only shift into reverse and back into park. It won't go past reverse to neutral or the forward gears. It was fine yesterday and has had no prior problem. Read something about a gear lock feature or maybe a fuse. Need advice quick. Thank you.
Old Jul 24, 2013 | 08:34 AM
joycesjag's Avatar
rwold, I had moved your post here as it was originally posted in the forum (site) help subdirectory.
Answer maybe be found under your vehicle (drivers side of transmission) 2 - 8mm bolts that anchor the shift cable to transmission have come loose, very common problem.
Good luck
bamforp
Aug 14, 2024 05:36 PM
Rlover
Mar 30, 2016 10:04 PM
user 652867429824
Oct 28, 2015 10:18 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
