Gearbox Fault codes by Newbie from Braintree, Essex
Old Apr 7, 2013 | 09:03 AM
police666's Avatar
i live in the uk.
i bought a Bosch 12V Silver Car Battery HSB019 from halfords Halfords | Bosch 12V Silver Car Battery HSB019
it costs £129.99, if you shop around you can find them cheaper, the reason i used halfords is i needed the battery right away as i had flattened mine a few times sorting out a borewash problem and it would no longer hold a charge poperly.
it fits and works perfectly.
Old Apr 9, 2013 | 02:44 PM
Comrade Gibby's Avatar
Thumbs up
Just to finish this off I found some part numbers for you.
Bosch #49-850B in the states Pep-Boys carry this under SKU #9073755
Also Dura-Last from Autozone will work #H8-DLG. This battery has a bit less power and is a bit more expensive so I recommend the Bosch.
Both have been reported to work and fit properly. As always check your application to be sure.
Thanks very much sir. I've found the bosch one at carparts4u at £76 postage free. Its a big one though almost like that of a track. What they did is that they asked for the plate number of my car, so after entering the number plate the full details of my vehicle came out, so I'm confident its the right type. Thanks
Old Apr 9, 2013 | 02:56 PM
Unhappy Gearbox now produces sound like a drum when accelerating
After the fault light gone now the car changes gears with some jerks andproduces sound like a drum when accelerating but when I stop accelerating thesound stops. Any suggestions honourable members? Please help.
Old Apr 9, 2013 | 04:22 PM
tbird6's Avatar
Has the transmission been serviced?
Fluid change and everything else plus the software TCM reflash?
Old Apr 9, 2013 | 04:34 PM
Mikey's Avatar
Be aware that the computers need to relearn good manners each time the battery has been disconnected. Give it a few days.
Old Apr 9, 2013 | 04:41 PM
Yellowfin's Avatar
Change the ATF fluid and make sure it has enough in the box. I just did mine and used Millermatic ATF DM (assuming you have the 6 speed ZF6HP26 box) after some research. More economic than the ZF/shell stuff and seems to work very well and is the same specification ATF fluid, also Motormania in Whitam stock it £30 for 5 liters.
Just change the fluid not the pan/filter and see if it improves the situation (You'll need 5 liters assuming its not low on fluid)... A decent mechanic should be able to change it in less than 1/2 hour (Mine did). Full instructions on the sticky on the UK forum. If it improves then go for the full change including the pan/filter (Bristol Transmissions) best place to buy them and consider the first ATF change as a flush. If it doesn't improve then its something more serious and at least you haven't wasted money on the pan/filter which is a bigger job to change.
Good luck
Old Apr 10, 2013 | 01:48 PM
Thumbs up
Hello sir, not really sure I've just bought this car, less than a month to be specific. Everything comes like a nightmare. Thanks sir.
Old Apr 10, 2013 | 01:55 PM
  #28
Thumbs up
Good luck
Hi sir, Thanks for your info. Im not sure of the type of the gearbox as I've just bought this vehicle, less than a month. Any help how I could know the type of the gearbox? Thanks once again.
Old Apr 10, 2013 | 02:30 PM
You have the six speed box in a 2003.
Old Apr 16, 2013 | 02:02 PM
  #30
Hello hon members Just a quick one on my past post concerning gearbox fault. Finally I've decided to change the transmission oil and see what happens. I will be updating members on this issue, thanks
Old Apr 23, 2013 | 03:26 PM
  #31
Jagbuff_UK's Avatar
Good luck
Very good advice and good to see a Jag owner that has done their research! I can vouch for the Millers Millermatic DM and the filter from Bristol Transmissions as this solved my fault where the gearbox 'specialist' said it required a new gearbox!
Initially I would change the gearbox fluid for some ATF III just to see if it cures the problem, and if it does then fit a new filter and flush with Millermatic DM. This is what I did to confirm that the problem went away with new fluid.
I can offer to do this for you as I have ATF spare that I got free, the tools and the know how.
Let me know if you meed this done as its not too difficult..... When you've done it once its easy to do it again
Old Sep 25, 2013 | 12:43 PM
  #32
Thumbs up Feedback on: Gearbox Fault Code (S Type 3.0l auto petrol 2003)
Hello Honourable members,
Yesterday I introduced myself to this forum as Comrade Gibby. I also brought with me a cargo of gearbox fault on my dashboard on my just bought Jag s type 3.0 L 2003. Gear stuck in 4th but can engage reserse fine.
Today I took the car for scan and got the following codes:
Gearbox-P0730, P0736, P0732, P0731
Engine -P1582, also p0731, p0732
After clearing these codes, the car drives normal but the technician told me that I should not bank on it. He it needs to recondition the gearbox.
Please could anyone help me,what step should I take?
I just want to give a feedback on theabove thread. I managed to buy the parts-sump pan which comes with the filter,sleeve and new 21 sump bolts at £103 from British parts.
The garage charged £100 for oil andlabour. The gearbox fault light is gone and the car is changing gears smoothlyexcept 1st gear which engages a bit forcefully,and 3rd gear produces some squealing soundwhen engaging.
I asked the technician if there weresome metals in the drained oil or old sump pan, he said no, but the oil wasvery dirt, burnt and very low, almost 2 litres.
The jar is on the road now and onobservation. I really appreciate all hon members who tried their best to givesome pieces of advice.
Please hon members advise, once againthanks.
Old Sep 25, 2013 | 02:20 PM
  #33
Default Feedback on the thread gearbox fault codes
Please hon. members advice, once againthanks.
Old Sep 25, 2013 | 02:52 PM
  #34
Default Feedback on Gearbox Fault Code
Steviedee1st
Nov 28, 2023 06:32 PM
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
tonyforman
Sep 10, 2015 07:23 PM
skadmiri1
Sep 9, 2015 11:27 AM
