Getting it back together
Old Jun 2, 2013 | 06:32 PM
Michael Star's Avatar
Default Getting it back together
Almost back together, but the picture of the twinscrew avos is working on for the STRs gave me an idea....
Old Jun 2, 2013 | 10:46 PM
Bad Cattitude's Avatar
Hmmm.. What could be next?
Old Jun 3, 2013 | 07:05 AM
GT42R's Avatar
nice, i just finished putting my STR back together after a 3lb pulley install, among other things,
interesting how much more room there is above the throttlebody with the cowl removed...
think i'm going to have to pull it off myself, as I managed to crack that plastic split-loom-looking hose that goes from the passenger side PCV valve to the back of the throttlebody area...
Old Jun 3, 2013 | 07:23 AM
Taking it all off is a bit more of a pain, but it is worth it in the long run to be able to get to things much easier.
Old Jun 3, 2013 | 12:13 PM
tbird6's Avatar
Why did you paint the blower white?
Old Jun 3, 2013 | 01:33 PM
Flat tan, when I cleaned it up to put it back on I couldn't just leave it bare. The aftercoolers will remain silver though, but the rest of the piping will be green.
Old Jun 3, 2013 | 05:07 PM
plums's Avatar
khaki green and tan ... trying for the camo look?
Old Jun 3, 2013 | 09:06 PM
I've got to blend in here in Kentucky!!!
Looks like I need to do some trimming
Old Jun 8, 2013 | 12:57 PM
The Chris X's Avatar
1. Badass! I'm diggin it Michael!
2. Bring that sucker to Pittsburgh so we can check it out in the flesh!!! And you can wind it out on the dragstrip!
Old Jun 8, 2013 | 08:13 PM
Working on a rough idle issue right now
Above 2k it is fine, but at idle it sounds like I have a lumpy cam. Time to track down the leak...
Old Jun 11, 2013 | 06:45 AM
Good luck! Got access to a smoke machine?
Old Jun 11, 2013 | 07:33 AM
Actually it was just a mis-seated TB gasket!! It is awesome now....
Old Jun 11, 2013 | 07:41 AM
Nice - glad you found the problem and it was an easy fix!
So is she all bolted back together and running on the road?
Old Jun 11, 2013 | 07:49 AM
Yup! The additions made seem to be well worth it. I am going to go to the drag strip tonight to see if I am faster than last time. The differences are: 1.5lb pulley, bored TB, Mina CAI, and 3" tubing replacing the factory flatish intake.
I hope it is faster, if not, then that will suck!
Old Jun 11, 2013 | 08:04 AM
ccfulton's Avatar
But you will look good going the same speed!
Old Jun 11, 2013 | 08:20 AM
So true!! I can admit that the blower is much louder now. Not that it translates into anymore speed, just that I can hear it over the exhaust (which is pretty damn loud itself). I did remove the packing beneath the blower as well.
Old Jun 12, 2013 | 07:48 PM
Hey part of the enjoyment of the car is the overall experience. If it all just came down to speed, well we'd all probably just ride crotch rockets. More blower noise = win!
The pulley should help you some, as well as the straight shot intake setup - nice job on that. Hopefully your track temps/conditions are comparable to whenever you made a baseline run so you can actually see if there is any difference in time. So many variables to control for....but you'll have fun regardless i bet!
I'm thinking you'll have some heat soak with that air filter setup after a run or two though and that particular item itself probably won't add much to the performance mix. These cars are just hot and seem to stay hot a really long time. Maybe I'm wrong, but doing something to isolate that air filter would help in my mind.
Let us know how she does on the track! And keep Pittsburgh in the back of your mind man!
Old Jun 12, 2013 | 09:48 PM
jag79's Avatar
Wow, just Wow, damm Michael as long as I have been gone from this forum, you have kept yourself dam busy bro! Congrats on the new setup. Looks phat! Did you noticed any gain in power since doing that mod?
Old Jun 12, 2013 | 10:00 PM
lol thanks! Someone had to pick up and run with it since so many are leaving!
The Mina intake setup sucks plain and simple. It doesn't close off the air intake from sucking in hot air, even after I used a lot of weatherstripping to try to seal it off. The only good thing I have going is the water/meth setup cooling things down.
I am thinking of Pittsburgh, I just have to see if I can get the time off work.
Rivguy
Dec 4, 2020 07:55 AM
Mugatu
22
Jun 23, 2020 01:50 PM
Bones
Sep 8, 2015 08:34 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
AL NZ
Sep 4, 2015 08:39 PM
