Gil
Old Jan 19, 2016 | 02:50 PM
Gilfrid Pereira's Avatar
Default Gil
S type 2005 2.7td
Hi, my car will not start, I get the error message gearbox fault, if I play around with the gear lever, it starts reluctantly.
I guess there must be a switch when in park which is not operating properly, if this is so is the switch inside the gearbox?
Hope someone can advise.
Gil
Old Jan 20, 2016 | 05:03 AM
JagV8's Avatar
It could be the j-gate assembly or at the gearbox - the latter tends to be caused by a loose or missing bolt(s). The shifter cable is meant to be bolted at the trans side - one or both can come loose / fall out and cause what you report.
Old Jan 20, 2016 | 07:02 PM
aholbro1's Avatar
Gil, post #18 should show a visual of the bolts John is referring to:
https://www.jaguarforums.com/forum/s...es-here-40522/
zidjan
Jan 12, 2016 03:23 PM
theshortwhiteguy
Jan 10, 2016 05:29 PM
Boomy
Dec 31, 2015 03:36 AM
ubetido
Australia - Queensland
Dec 29, 2015 02:38 PM
scooby73
Dec 28, 2015 12:41 PM
