Good Indy required
Old Apr 18, 2013 | 07:35 PM
philB_STR's Avatar
Default Good Indy required
Hi, anyone recommend a good Indy near Manchester, England?
Also anyone know what the code P0781 is? Not seen this one before, have had a few P0171 and P0174 which seem to be a leaking vacuum hose and goes away for a few weeks then pops up again while driving slowly. Thought i had this fixed after i tightened up all hose connections as it disappeared for weeks. Think i will take car to an Indy now and get it sorted for good as its due a service shortly.
Old Apr 18, 2013 | 09:10 PM
QuartzSTypeR's Avatar
That's a transmission 1-2 shift malfunction code. Likely just needs a TCM reflash.
Old Apr 19, 2013 | 04:53 AM
JagV8's Avatar
Check LTFTs using OBD live data. If you've an air leak find it soon as cats are at risk.
Make sure trans not low on oil.
Old Apr 19, 2013 | 11:59 AM
philB_STR's Avatar
Thanks for replies, there is some differences in live date LTFT 18.0 and 19.5 at idle, i will check the STFT tomorrow. Anyone know a good Indy in North West or Yorkshire?
Old Apr 19, 2013 | 02:02 PM
JagV8's Avatar
Forget STFT. LTFT should be near 0 (say +-5%). Rev to say 2500 and if they head near 0 then you know it's a leak. As they're similar you'd be looking for a leak before the sides split going to the 2 banks.
Old Apr 19, 2013 | 04:11 PM
tbird6's Avatar
You did not answer? Has the transmission been serviced at all? At least a fluid level check?
way2far
Aug 31, 2022 09:26 AM
vsol
Aug 29, 2018 09:46 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
XJsc-guy
Sep 2, 2015 11:43 AM
