Hard Start after fueling
Old May 25, 2017 | 07:13 AM
03s-type_sport's Avatar
Default Hard Start after fueling
My 03 has started to have issues after I fuel the car. It doesn't want to start up initially after fillup. Is this a fuel filter, fuel pump, fuel screen issue or something else?
Sometimes when I remove the fuel cap, the rubber O-ring on the cap slides down the cap due to the amount of suction in the system. This had not happened before that I can recall until this issue.
I plan on replacing all the filters soon anyway. If the pump is the issue, I will replace the pump at this time also. I would buy a new E2226 pump (Motorcraft) for the unit.
Old May 25, 2017 | 08:01 AM
JagV8's Avatar
Pump appears to be working.
Something is supposed to "breathe" and apparently isn't.
Old May 25, 2017 | 11:59 AM
Such as?
Old May 25, 2017 | 04:43 PM
Ducmon's Avatar
If you watch this video he will show how to check the fuel pump using the fuel trims.
https://youtu.be/cARQ0jZZ4Qc
but it sounds more like that you have a problem with the fuel tank pressure control valve.
If you downloaded a copy of the JTIS from the stickies or the workshop manual from jagrepair.com it will tell you how to check it.
Old May 26, 2017 | 05:52 AM
Thank you. I have a copy of the JTIS. I will look at the video and JTIS. From the diagram listed above, I thought the fuel pump was located in the left wheelwell and not up under the vehicle near the tank. Is the diagram correct? Was the wheelwell location for a different MY?
Old May 26, 2017 | 07:45 AM
aholbro1's Avatar
For an 03 3.0L V-6, your fuel filter should be behind the splash shield at the back of the left front wheelwell. Your pump should be inside the tank.
Old May 26, 2017 | 08:09 AM
JagV8's Avatar
And the filter(s) aka sock(s) in the tank (I think).
Old May 26, 2017 | 08:38 AM
JagV8 and aholbro1 correct. The illustration shows the filter by the pump which is incorrect.
Old May 26, 2017 | 04:30 PM
Ducmon's Avatar
The picture was of a 2000 car it was the only one that I could find to show the pressure relief valve.
Old May 27, 2017 | 06:17 AM
Is the pressure relief valve in the same location as on an 03 By 3.0?
Old May 27, 2017 | 02:32 PM
Ducmon's Avatar
download the epc https://www.jaguarforums.com/forum/x...uctions-48195/
and the JTIS they should point you in the right direction
or go to Jagrepair.com and download the workshop manual as a PDF
Old May 28, 2017 | 06:26 PM
Thanks for the EPC info. I have the manual and JTIS. I was only asking if it was the correct location so that I didn't have to check and see, but I will. Once again, thanks for the EPC info.
