Heat recirculating option turns off
Old Nov 21, 2022 | 04:58 PM
kiloslanga's Avatar
Default Heat recirculating option turns off
Not sure if this is how the climate control system has always worked, but I have just recently moved back to a cold climate and every minute or two I must press the interior recirculate button on the climate control or it pulls the hot air from the engine instead of cabin.
Old Nov 21, 2022 | 05:43 PM
kiloslanga's Avatar
02 s type v8
Old Nov 21, 2022 | 09:02 PM
motorcarman's Avatar
PRESS and HOLD the recirc until it BEEPS for continuous operation.
You need to do this EVERYTIME the car is shutdown and restarted.
Old Nov 22, 2022 | 03:29 AM
JagV8's Avatar
What Bob (motorcarman) said.
It's a little annoying and if you forget then the stink of a diesel reminds you... (but too late)
Old Nov 22, 2022 | 11:29 AM
kr98664's Avatar
I played with the Recirc button on my '02 this morning.
If pressed briefly, you'd get a single chirp and the system would automatically revert to fresh air after approximately 5 minutes.
If held for several seconds, you'd get a double chirp and system would stay in recirc mode. IIRC, at next engine start, the system would still switch back to fresh air mode.
With either option, the general logic seems to be avoiding continually running in recirc mode. Moisture gets trapped in the cabin and it makes it harder to keep the windows clear.
What ambient temperatures are you experiencing? Normally fresh air mode is more than sufficient for heating. With everything in good working order, you've got a virtually unlimited heat source under the hood and the heater shouldn't have any trouble keeping the cabin warm. AFAIK, recirc mode is really only intended to help the AC system cool the cabin when heat-soaked. Some people use it to momentarily block out stuff like diesel smoke when stuck in traffic, etc.
If you suspect inadequate output from the heater, please see this troubleshooting guide, specifically posts #2 and #6:
https://www.jaguarforums.com/forum/s...rol-how-185002
And this one:
https://www.jaguarforums.com/forum/s...repair-251854/
FWIW, on my pickup, recirc mode is labeled Max Cooling and is only available with the AC on. You can't select recirc by itself, such as when running heat or defrost.
Old Nov 22, 2022 | 02:52 PM
JagV8's Avatar
Diesel is in dire amounts here so I've used recirc all the time for years - and not had moisture problems.
kbeachy
20
May 20, 2021 11:18 PM
Savagebeast1284
Jul 21, 2014 11:14 PM
Sinister 1
Dec 17, 2010 02:11 PM
william young
May 28, 2009 04:24 PM
jagular
Feb 24, 2009 07:15 PM
