Heater
Old Jan 14, 2022 | 06:40 PM
Wallaga's Avatar
No not control panel that may need the repair as shown in the picture it's the DCCV on eBay I bought one for $ 55 delivered works fine look at them all you will see that they are all the same and built-in China it's just the price that varies"
Old Jan 14, 2022 | 11:08 PM
knares's Avatar
Thanks for your interest and comments/advice.
When I got the readings the other day, I immediately ordered a DCCV.
To day I removed the DCCV from the vehicle and it looked ok, not gunked up, not rotted
I put a ohms meter across it and it read around 15.9 ohms, both sides about the same.
I put 12v to it and each side opened and closed, so I think its ok, that’s assuming 15.9 ohms is ok.
When the new one comes I will check what ohms it reads.
Old Jan 14, 2022 | 11:13 PM
knares's Avatar
kr98664Your experiment, I found interesting none the less
Old Jan 14, 2022 | 11:48 PM
knares's Avatar
pin 2 to ground 11.59v
pin 2 to pin 1, 0.04v
pin 2 to pin 3, 5.21v
Old Jan 14, 2022 | 11:54 PM
knares's Avatar
Wallaga
now it looks like i am up to your page haha
Old Jan 19, 2022 | 09:06 PM
knares's Avatar
hi guys, i cant for the life of me find a fuse listing, i have a listing fore the relays
in the front power distribution fuse box, i have two fuses missing, no F14 and no F34, they are 15A.
should i have fuses in these spots in my 2003, V6 s-type and what is D3 and D4, are they fuses.
as it looks like i have to remove the dash, can i up grade it with say a 2005/6 type dash
thanks
Old Jan 20, 2022 | 04:37 AM
JagV8's Avatar
No.
Old Jan 20, 2022 | 05:23 AM
  #28
kr98664's Avatar
as it looks like i have to remove the dash...
Huh? Is something else going on? There's no need to touch the dash when replacing the DCCV.
Or are you talking about removing the control module for an inspection? That's always a good idea on a 2003+ model when the DCCV acts up.
https://jaguarclimatecontrol.com/new...-way-to-do-it/
As far as those missing mystery fuses, some blank spots may have been for optional equipment not installed. Wiring diagrams here with more details:
http://www.jagrepair.com/JaguarSType...OBDIIcodes.htm
Old Jan 20, 2022 | 06:25 AM
knares's Avatar
Perhaps I should have said “centre consol”
Old Jan 21, 2022 | 02:43 PM
  #30
kr98664's Avatar
Had a little more time to look. Those two fuses are for optional HID headlamps, which I'm guessing your car does not have. In the front power distribution box, you probably don't have relays R10 or R13, also part of the HID lighting system.
See figures 01.2 and 08.2 here:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Conventional lighting is in figure 08.1.
Might want to update your signature. It still says 2002. Lots of differences pre- and post-facelift.
and what is D3 and D4, are they fuses?...
Pictures?
Old Jan 21, 2022 | 07:42 PM
  #31
knares's Avatar
"Might want to update your signature."
i have tried several times
Old Jan 22, 2022 | 04:38 AM
  #32
knares's Avatar
well, there is a problem it looks like.
But how do I repair that, I have repaired boards in an earlier life, 65 years ago but they were no where near that fine
Old Jan 22, 2022 | 04:39 AM
  #33
knares's Avatar
Wallaga
i am on your page
Old Jan 22, 2022 | 05:14 AM
  #34
knares's Avatar
this is the part i was asking if i could replace with one from a later year, say 2005/6
Old Jan 22, 2022 | 09:04 AM
  #35
kr98664's Avatar
But how do I repair that?...
You don't. Save yourself some major grief and send it off to be repaired AND upgraded so it doesn't happen again:
https://jaguarclimatecontrol.com/repair-and-upgrade/
Resist the temptation to bridge the damage with a jumper wire:
https://jaguarclimatecontrol.com/new...t-to-see-this/
You have encountered a VERY common problem on 2003+ cars. This is not uncharted territory. The problem is so common, a guy set up a small business to repair and upgrade these modules. As stubborn as I can be, if I were in the same situation, it's still time to pay da man and have it done right.
Old Mar 1, 2022 | 07:13 AM
  #36
knares's Avatar
Hi again
My heater valve arrived at last, two months it took.
Before I took the centre consol out, I disconnected the battery.
Now I have found the key doesn’t fit the boot/trunk.
How do I fold the rear seat forward so I can get to the battery
thanks
Old Mar 1, 2022 | 08:37 AM
  #37
kr98664's Avatar
Before I took the centre console out, I disconnected the battery.
Here you go:
https://www.jaguarforums.com/forum/s...ng-port-87362/
If you can get in the cabin, open the hood and connect power via the front power distribution box as detailed above. Or access the +VE stud behind the wheel liner for the right front tire. With either method, you should then be able to open the trunk via the button on the dash.
Old Mar 3, 2022 | 03:17 AM
  #38
Aarcuda's Avatar
Dont bother trying to read milliamps. These cars are so old theres resistance in every connector. Looks for my post on the climate control module. Lots of pictures and I believe I posted the part number for the resettable fuse that is used to replace the burnt out trace. The ground is switched with a transistor in the CCM if I recall but not sure of the pn. I may have posted it. Cant recall. Its easy to pull the CCM and open it to see if the traces are burnt. Its probably sufficient just to measure ohms from the fuse block (fuse out) to each ground wire on the ccm connector. If they dont match the valve probably isnt any good. Its unlikely theyll both fail and read the same resistance unless its 0 or open. Id say 0 or open says the valve is bad. If a trace in the ccm is melted the valves bad.
Old Mar 5, 2022 | 02:24 AM
  #39
knares's Avatar
i got the boot open, got the power point under the right gaurd, thanks all
Old Mar 6, 2022 | 10:19 PM
  #40
knares's Avatar
i have looked for it, cant find it
